1 - 4 of 4 Posts
· Banned
Someone told me that if the ECU cannot read the water temp from the radiator it will not let you go more than 500 rpm...
Are you using a B series temp sensor? Or a k-series one? Are you getting proper reading for temp?
NIkos
What is the specific dtc number it is throwing?
You shouldnt have to run a different temp sensor at the engine,only at the adaptor pipe for the cluster.I have run without that sensor,and have had no problems with vtec.
1 - 4 of 4 Posts
