1 - 19 of 19 Posts
I am planning on doing this swap this spring in my 94 hatch. I can get the type-s swap for around $4000 and the type-r for $5300. Is the type r really worth the extra $1000?? Also w/ the type r he said the harness isnt always complete, what do i do if it isnt??
Banned
The type r has different pistons, cams , manifold, throttle body and a LSD transmission.
If you are planning to stay all motor and can afford it, go with the R.
The transmission alone goes for $2000 in the US.
If you are planning to go turbo, go with a type S.
It is worth that extra $1300, unless you are the kind of person that will end up porting the head, changing the cams and going all out... Then the type S would be better.
Deep said:
What are the numbers on the K20R transmissions? and the RSX-S??
This is for 2004 and 2005 type s
Type r tranny
Gear Ratio 6MT
1st 3.266
2nd 2.130
3rd 1.517
4th 1.212
5th 0.972
6th 0.780
reverse 3.583
Final gear ratio 4.764
2004 type s
Manual
1st gear 3.267
2nd gear 2.130
3rd gear 1.517
4th gear 1.147
5th gear 0.921
6th gear - - 0.738
Reverse 3.583
Final Drive Ratio 4.389
2005 type s
1st 3.267
2nd 2.130
3rd 1.517
4th 1.147
5th 0.921
6th 0.738
Reverse
3.583
Final Drive
4.765
Discussion Starter · #7 ·
i think i am gonna go w/ the type-s since they are much cheaper. this way i can get k-pro instead of running type r ecu b/c if i go w/ type r i cant afford k-pro. How much would it cost to add lsd??
The LSD is about $850 plus labor.
Trust me go with Type r....
Look at the gears and the motor...
The type r at the long run is a lot cheaper and better...
But hey it's all up toooo you.. :p
This things that motor comes with..... If you only know :wink:
Discussion Starter · #15 ·
just wanted to say thanks for all of your help fellas, couldnt do it without ya, no one around here even knows about this shit. they are still swapping single cam v-tec motors in their cars around here. they really gotten into b series yet, so there really isnt anyone that knows what they are talking about aeound here.
TeamPacman said:
This is Type S
This is Type R
bwhahahahahahahahaah - thats sooooo funny BUT TRUE. my jdm k20a type R just got in the states (thanks passwordjdm.com) I will have my stock DC5-R LSD for sale in a couple of weeks - I am replacing it with a quaife unit...not too mention toda flywheel, exedy stg 2 cerametallic clutch, mugen head gasket (.4+ CR), hondata IMG & K-pro...
its only a matter of time now :shock:
Totally worth it to get the Type R...I love mine. Plus in the long run, even when you change things you can sell the Type R parts for good money to people. :up:
that is ture
but how much do type-R engines go for
where is a good place to get one that is'nt a rip-off
jhpusa.com sells it for $6k but i have seen then for $5300-$5,500.00
are they all going for $6k now?
1 - 19 of 19 Posts
