1 - 9 of 9 Posts
i just bought a brand new Type S engine harness and a new charge harness for my K24a2 swap for my EG...I'm using the Hybrid racing conversion harness as well... What sensors , if any do I have to switch to make this work???As well as will these harnesses work on this swap for my EG??? I'm new to the k-series stuff and i don't know what will work...thanks...
mostly plug and play.....
the only sensor you change is the crank position sensor. just cut the plug off your stock tsx harness and rewire it onto the type s because the shapes of the 2 plugs are slightly different. It cheaper than buying a type s sensor and replacing that.
nothing on the charge harness?
GoldStar
chameleon said:
dont bother cutting. simply get a paper clip and take the safety clip out of the plug, and lift up the lil holders on each pin and pull them out. just reinsert them in the tsx plug but following the tsx wire colors.
no cutting necessary.
yes, repining is best :up: .
1 - 9 of 9 Posts
