1 - 11 of 11 Posts
... if its cheap I wanna check it out... its for a newER civic FD/FG/FA/FN chassis..what does he want for it???
that ecu can not be modified for k pro
its only use is on that same year and model car it came out of
im 80 percent sure that ur car will run with the computer, but it is not able 2 b tuned. i was also under the impression that u can have it kpro'd, but most people who use this computer dont have that done cuz its more expensive the a prb ecu.... i am probably wrong, but jus putting it out there
is it drive by wire, or just use the 05 up engine harness
Yes its DBW, the ecu has no controls for IAC and it needs a MAF sensor to run.
No, your a littel off, well a lot, a close quote of Dickhead from Hondata, The new honda ecus are different then any of the older ecus, (06+) Hondata can reflash those ecus, but they use a CAN interface not an ISO, so you cant use K-pro, because K pro is meant for another type of computer language.
the people who have made Kpro work in there cars either are using an RSX harness with a K-pro'd ecu and no dash function, or they are running a Dual ecu set up where the Kpro's ecu runs the engine, and the stock ecu runs the dash and other things.
1 - 11 of 11 Posts
