z10 said:whats the point of getting 52mm since the intake ports are alot smaller?
what was your motor setup when you did the test?I take a guess which one it's better..
yay, it's cut off in the pic he posted and i cut mine off when i put mine on too.NAturalDC2 said:Someone tell me if this is true, I heard that the water pump will not fit unless the tensioner bracket is cut off, yay or nay?
rsca_crx said:what was your motor setup when you did the test?I take a guess which one it's better..
Nope...suckafree said:do the haywards come with injectorws// what style injectors//bungs??
Hayward performance will be coming out with a drag race only version which has the option of having the injectors on top or on the bottom, or dual injectors top and bottom, the injector bosses are for Bosch style injectors, so people can get any size injectors at lower costs this way.jon v said:Nope...
Quote from lance- Everyone wants different sizes, so I don't supply injectors except for the S2000 system which requires the smaller Pico type to fit under hood.
So what will be the major difference's between your Drag setup and the normal setup?LHP said:Hayward performance will be coming out with a drag race only version which has the option of having the injectors on top or on the bottom, or dual injectors top and bottom, the injector bosses are for Bosch style injectors, so people can get any size injectors at lower costs this way.
You can get Bosch type injectors almost anywhere, in lots of flow rates.
Please keep in mind that this race only version might require hood and other modifications so as to fit engine, power steering etc.
Will be offered in 54m/m to start, with other sizes as needed.
These are 4 to 6 weeks away.
Thanks:LHP
Go to this pageH2nr said:does anyone make some that have the rail on the bottom so the hood will close on an EGK20 with ITBs?
haha thats my carhcar said:
