need help...!!
What am i to do about the right side of the k20z3 head where the coolant runs through??? I saw a thread where someone mentions that hasport makes something for it, but i can not find...
another solution was to tap into the hole, but im not too fond of that idea either because the wall seems way to thin to catch at least three thread
also..
where the power steering pump/ep3 idler pulley bolts to the bracket above the water pump.. there isn't enough clearance to have the ITBs installed,
if i customize that bracket, it will leave me with only two holes instead of three to bolt up back the ep3 idle pulley
any suggestions?!
thanks
also..
any suggestions?!
thanks
