i've got a bunch of parts that i need to start getting rid of. all parts are pulled and sitting in the garage and i'm working on getting pics as i get the parts cleaned up.
please PM or post any questions.
Innovative motor mounts - all four $250
AVC-R boost controller $250
Turbo kit : $1850
- side mount manifold by TD Autoworks
- SC61
- revhard FMIC with all couplers & pipe
- BOV (came with the rev hard kit)
- 3inch downpipe with v-band flanges and recirculated waste gate
- 44 mm Tial waste gate
- 3bar map sensor
- GM boost solenoid
- precision 750 cc injectors
- oil feed & return hoses and fittings
revhard cast iron turbo manifold $100
revhard wastegate (38 mm ? ) $75
autometer boost gauge - mounts inside left drivers AC vent $30
autometer oil pressure gauge - mounts inside right drivers AC vent $30
K20 shortblock currently dissembled, comes with most parts (pistons, rings, bearings, crank, timing chain & cover) $200
Type S 6spd transmission : blown 4th gear, cracked bell housing $300
TSX 6th gear set - un-used
billit aluminum vacuum block $45
'03 OEM headlights
'03 OEM type S suspension
CC lightened flywheel $100
Turbo kit : $1850
- SC61
- 3bar map sensor
- GM boost solenoid
'03 OEM headlights
