1 - 15 of 15 Posts
Car Made 300whp 300ftlbs At 10psi With The Stock Head Just Finished Street Tunning 6 Psi With The Rsx Cams And Its Pulling Much Harder Up Top 5000 To 7200 Redline Feel A Little Sluggish From 2500 To 3500 But Once Vtec Is On Pulls Very Hard TOMMOROW I WILL Finish Street Tunning To 10 Psi In 3rd 4th 5th And 6th 1st And Second Dont Hook At 6 Psi But Pulls Hard Motor Is In A 2001 Em2 Will Dyno At The End Of The Week Post Vid Then CAR IDLE WAY BETTER WITH THE RSX CAMS THEN THE STOCK CRV USING 1000CC INJECTORS
Discussion Starter #4
Cyber Manifold Sc-61 38mm Wastegate 3inch Downpipe Stock K24a1 Motor Rsx Intake Manifold Hondata K-pro
Discussion Starter #5
Dynoed 8.2 Psi 300 Whp 300ftlbs 7400 Redline Turning Up To 10 Psi Tommorow Need Time To Do Alot More Cam Tunning Think She Got More In Her Any Cam Map Suggestions How Much Avance Till How Far In The Redline Before Retarding
how is the head setup?
any info at all on the head would be appreciated
im about to do the exact same thing
Discussion Starter #8
the head is a stock k24a1 with k20a2 rocker arms and cams just reversed the locking rods for vtec to work with out the lost motion springs i found the writeup how to on k20a.org
went back to dyno 10 psi made 335whp 300ftlb need more time to tune ignition is conservative due to pump gas will be switching a 50/50 water alky mix from 8 psi to 12 psi shooting for 400whp hopefully
anyone hit 400whp on k24a1 or k24a4 yet
Hows your A/F? What size injectors and what duty cycle are you running them at?
I think if you turn it up to 14-15psi you might hit you 400whp marker on pump safely. Anyway good luck.
Suscribed.
Discussion Starter #15
had the head around will be tunning to 18psi with water meth need 4th gear pulls third just spinnin in a 2001 em2 car is for sale 17000 trades welcome
1 - 15 of 15 Posts
