1 - 6 of 6 Posts
Banned
What a/f do you guys shoot for?
Target says 14.7. Datalog is around 13.5.
Should I Raise the low cam to around 14.7 and the high cam to 13.2?
It depends, there is partial throttle and full throttle still in low cam.
On cells 1-3 would shoot for that 14.7-15.0
On cells 4-6 would start shooting for that 14.3-14.7 range.
On cells 7-10 would start shooting for a 13.2-14.0 range. When you have cell 9 and 10 you wanna be around the 13.2-13.0 range.
Its kinda hard to explain exactly what im saying. But you will understand and you just want it to be smooth transitions.
I understand that.
Whats the best way to tune for partial throttle?
Banned
I understand that.
Going through datalogs, because there is 0*,10*,20*,30*,40* and 50* low cams. So you have to tune 6 low cam maps, you have to lock each and every degree starting at 50* then copy the fuel maps, paste onto the 40* map and so on and so on. By doing the copying it will make fuel adjustments pretty minimal from cam angle to cam angle.
Discussion Starter #5
Gotcha. Thanks.
Do you use lambda overlay?
1 - 6 of 6 Posts
