1 - 4 of 4 Posts
Hey whats up? I wanna get my project on the go. Im running a pretty much stock Type S, except i have 52mm ITB's and DTR header. Can someone help me if they have a similar setup with a base map; like how much fuel i should run, air fuel ratio settings, timing, vtc settings, etc. This would help me out ALOT. oh yah, i plan to be running 94 octane all the time. thanks. :worship:
You need to get on a dyno. A half decent base map will be a good start. But some serious dyno time is the only way to get the best out of it. Don't cane it till you have, god only knows what the AFR is...
there is a map for a ITB set-up in the K-Managaer from Hondata. Its free to download, although being that its run on 110 octane your car will run rich as hell to start with, be just a case of adding master fuel in, if the K-Pro has that function.
Anyway good luck I hope you get some good power..
1 - 4 of 4 Posts
