1 - 12 of 12 Posts
Does the tsx final drive fit in a k20 tranny? if so if i was to buy are they cheaper than buying a 05 rsx final drive... so should i go to a 5.0 final... I AM DRAG RACING THE CAR... with stock valvetrain on a type s tranny... i dont want to get into 5th when racing...
thanks guys
Yes all the K series tranny stuff is interchangable...
2005 RSX Type S:
23221-PZF-000 COUNTERSHAFT 285.10 228.08
91003-PPP-004 BEARING, NEEDLE (35X68X20) 38.60 30.88
41233-PZF-010 GEAR, FINAL DRIVEN 176.48 141.18
2004 TSX:
91003-PPS-003 BEARING, NEEDLE (35X68X2) 38.60 30.88
41233-PZF-000 GEAR, FINAL DRIVEN 176.48 141.18
2004 Civic Si:
23221-PPP-000 COUNTERSHAFT 280.14 210.10
91003-PPP-004 BEARING, NEEDLE (35X68X20) 37.94 28.45
41233-PPP-000 GEAR, FINAL DRIVEN 176.64 132.47
fyi guys, most honda parts that seem the same but have diff part #'s and cost diff, it usually only means one part was made here and the other over in japan, hence the reason the TSX parts cost more even though its the same as the civic b/c it was made in japan
humping_dragon said:
2005 RSX Type S:
2004 TSX:
2004 Civic Si:
I believe you are not supposed to use the TSX bearing for this setup, make sure to use the Si bearing or 05 RSX bearing if you are going to use the TSX FD
the k20a type r trans already comes with the 4.764 final drive ratio. as does the 02+ ep3 civic, the tsx, and the 05 rsx-s. the 02-04 rsx-s got the 4.389 final drive. use the needle bearing to match the countershaft you are using. ep countershaft=ep bearing......
1 - 12 of 12 Posts
