Last night, the shop and I loaded up the K-Pro with the cold-air tuned base map after I saved a file that included the immobilizer, multiplexor, and OBDII disabled.
Background:
I noted that the software version I have on my K-Pro is 1.0 and the Hondata site is using 1.6.
Everything is plugged and wired up properly (or so we think). The car is an OBD1 DC2. The wiring harness is Hybrid-Racing.
The issue:
With everything powering up, the car turns over but does not light up. Fuel pressure is reading 0. Upon further investigation, the fuel pump doesn't prime when power is turned to "on".
What we've been looking through:
Everything is grounded properly. All lines, vacuum hoses, etc. are on correctly. The only thing we can trace back to is the wiring at/near the K-Pro/ECU. With datalogging on, and the K-Pro plugged into the laptop, there is data being recorded on many sensors from the instant ingnition is turned "on" and we try to turnover the engine. Ignition reading is obviously "0".
We are now stuck on the "jumper" wire mod. The Hybrid-Racing instructions tell us to connect (from the car's "A" harness) the A7, A8, and A9 wire together. Also connect the A13 and A20 wire. Finally, jump the A23 and A24 wire. On my car, I don't have an A8, so we've jumped the A7 and the A9 (one is a green while the other is blue). Is what we've done correct? If not, what are we doing wrong?
Pleas of help
PLEASE, PLEASE give us some suggestions at what else to look at or tips on wiring.....I want to drive my car!!!
Back to a moment of maturity:
Thank you in advance for any suggestions, ideas, or help.
Background:
The issue:
Pleas of help
