1 - 1 of 1 Posts
When the motor is running, the tranny wont go into gear. With yhe car off it does as it should. I just installed a new clutch, flywheel, throw out bearing in my rsx and bled the hydro line. When I disassembled the tranny from the motor I took the shifter cables off in one piece via the 3 bolt bracket that holds them in place and put them back the same way. Maybe is there adjustments need to be done? Anyonee have any suggestions?
1 - 1 of 1 Posts
