1 - 5 of 5 Posts
Car was running fine, took the manifold off (didnt touch the TB) to swap motors.
Note: I didnt remove the wiring harness or touch it at all....
Put the manifold back on, car started for a second, sputtered and died. In KPro got a Map sensor low voltage code, figured I got the MAP and TPS plugs mixed up, switched them, car wont start, battery doesnt have enough voltage.. with KPro online but the car not running TPS stays at 112% with the pedal at rest and if I put it to the floor it will read 113% sometimes. Tried adjusting the TPS from one extreme to the other.. still the same 113%
Will the TPS go bad if the MAP plug is plugged into it? Any ideas? I tried uploading a basemap but I get the same result...
I have the same problem.. wen i was running the type r ecu i have to switch the map and tps to start the car. now i got kpro and it wont start at all.. but wen i switch the map n the tps again it will start for a second and it's spudders too then it dies.. Someone help US out lol..
Chris, tps is green,red,yel as the dominate colors... make sure its on the right plug. Since you didnt change anything I really cant say whats wrong... :(
low voltage means that you may have a short to ground or low resistance on that particular sensor/wiring. what is your battery voltage on Kpro check for voltage drop at fuse box main fuse and positive batt terminal use the neg terminal and then an engine ground. use a DVOM for this.
Discussion Starter #5
The battery is weak but I charged it overnight, car starts fine now, getting a TPS high voltage code... guess its time for a new TPS...
1 - 5 of 5 Posts
