SOME ONE HELP ME PLEASE!!!!!!!!! i need to know the timing chain marks on a k20a2?????
Theres a arrow on the side of the block pointing down at the crank pulley, on the crank pulley there are 4 close indention marks on the back pulley lip, a white, blank , red and another blank. Line up the arrow with the white indention, there are very hard to see from up top. After you have that setup there is a line and dot on the EX/IN cam gears, u have to line up the lines on each gear so that they both make a straight line with each other and that the dots are facing straight up about 12 o'clock. Last thing is that there are 3 black chain links, one for the crank gear and 2 for the cam gears, on the cam gears the black links have to be lined up on the gears teeth where the dots are locacted. Pretty much it, hope this helps you out alil better.K24typeSturbo said:SOME ONE HELP ME PLEASE!!!!!!!!! i need to know the timing chain marks on a k20a2?????
