1 - 5 of 5 Posts
ok I'm pretty sure I did it right but wanna double check..
cam gear arrows point in between the gray links and same with the crank??
right..or wrong...
car wont start no spark no injector pulse...Kpro..
disabled the immoblizer and still nothing...
anyone ever came across this problem..?
any help would be apreciated...thanks..
did you use the dots as pointers?
Chain has 3 colored points you need to match... each cam gear has a dot and then last colored link goes on the dotted crank gear tooth
1 - 5 of 5 Posts
