the k20, k20a post
well i wanted to start a thread with all the k20a info you'll need to know about the engine and swappability. So here is some info i've gathered:
basically to do a swap your looking at Minimum:
$3500-$5500: k20a engine
$575-$650: Hasport engine mount
$350-$399: Axles
$350-$399.00: refabricated hasport header
$300: wiring harness
$575: hondata ecu
To keep your AC:
$81.28: EP3 belt
$92.25: EP3 Bracket w/pulley
You will need these parts to accomplish various tasks as well:
Golden eagle rail $125.00
Fuel Lines $225.00
Fuel Regulator $200.00
Shifter Box (aj racing) $125.00
AEM intake RSX $225.00
Shifter cables $355.24
Throttle cable $25.38
Shifter linkage Clips $11.10
3 Bracket 31175-pra-000 $39.96
7 Pulley 31190-pra-000 $22.61
5 Bearing 31185-pcx-003 $5.14
12 Bolt 10 by 25 90031-pra-000 $1.48
Thermo unit $21.85
97 cable $22.53
Switch Coolant $25.99
Will at Hybrid racing filled my in on some of the various parts needed:
So far some of the best info i have found about the k20a and its swappability is from:
Hybrid racing:
Hybrid racing articles
Hybrid racing k20 forum
k20a.org:
F20C and the K-series motors, by brian g (from hasport development)
Great axle info!
Axle info, with a few pages of unneccesary fighting.
k20a parts:
true racing, for racers not ricers
rsx tuners, though their site is down now ?
Hytech exhaust, which was really good but their site is down also?
Of course Hasport
Todda racing
k-20A Engine Swaps:
Password JDM
sunrise jdm
hondaacuraautoparts
jdmaddiction
jspecautosports.com
motor mounts:
full-race.com has it for $575
Of course hasport but they quote $639 on their site
fabricated headers:
hasport header
Axles:
hasport axle
(more at axle packages below But read axle posts above!)
Wiring harness:
Not sure anyone got a link?
ECU:
hondata kpro
k20 engine kits:
www.nitrodriveline.com
spool
intermediate axle
outboard axle
knuckles
wheel hubs
brakes
Axles built depending on your setup: gatorinc axles $3600
both axles
General Info and engine specs:
k20a swap articles:
aj racing
honda tech
So basically if you can post direct information or pm me or an admin to change the info above that would be great. If we can minimilize the questions about the engines and swaps on this thread and keep this thread as clear cut as possible i think it would be helpful.
$350-$399: Axles
$575: hondata ecu
To keep your AC:
$81.28: EP3 belt
Fuel Lines $225.00
Thermo unit $21.85
97 cable $22.53
---------------------------------------------------------------------The bracket, pulley, bearing, and bolt are needed to remove the Power steering from your K series motor. Here is a picture to show you how the parts work.
http://www.hybrid-racing.com/~stank....php?pic_id=274
This pulley setup is not needed on any motor that came from the EP3 Civic.
The Thermo Unit and Coolant Switch are used to control the fan and the temp gauge in your chosen chassis.
The remaining part is the throttle cable and this is used for throttle body actuation.
Let me know if you have any other questions.
Thanks,
William Davidson
1-985-951-8588
Hybrid racing:
k20a.org:
Great axle info!
k20a parts:
Of course Hasport
Todda racing
k-20A Engine Swaps:
Password JDM
sunrise jdm
hondaacuraautoparts
jdmaddiction
jspecautosports.com
motor mounts:
fabricated headers:
hasport header
Axles:
hasport axle
Wiring harness:
ECU:
hondata kpro
k20 engine kits:
Axle kit: $5600Quote: Here's the quote from John at Hytech posted on www.clubrsx.com:
"As promised here is the price for the kit. For most of you it is expensive but that is life. Good parts and good quality is what we are pushing. This motor, in street form makes more power than the Real Time RSX, for the world challenge series. And I bet their motors go for a whole lot more than what mine does. We will be manufacturing the first 10 kits ASAP. The only things left to be done is to finalize the new cam profile and the new intake manifold. Which will push the power to 280 whp. Realistically about 6 to 8 weeks before we have the kits ready to go. For those who are serious you can call me at (949) 581-2181 and we can answer your questions and take deposits.
Billet Connecting rods
Custom Wiseco Pistons with pins and rings
Chevy IRL valve springs and Ti retainers
8620 billet roller cams
New intake mainfold
Stainless racing header and 3 inch exhaust
Ported cylinder head with new stainelss valves
Custom intake with filter
Reflashed ECU.
spool
intermediate axle
outboard axle
knuckles
wheel hubs
brakes
both axles
Originally posted by George Knighton from honda-acura.net on Oct/31/04
The K20A is the DC5 ITR motor. Very expensive.
The K20A2 is the USDM Type S 200 HP motor. Expensive.
The K20Z1 is the USDM 2005 Type S 210 HP motor. <-This is awesome, but rare in the motor factor yards and veyr expensive.
Two things to think about that you mightn't think about at first thought:
(1) K20A3 is the 160 HP 2.0 litre EP3 Si motor in the USDM. This is a very torquey motor that's very pleasant to drive, very flexible. They are very cheap because of all the EP3 USDM people doing conversions and then not having anything to do w/their motors.
(2) K24A* is the 200 HP motor in the USDM CL7 (TSX). This is exactly the same size dimensionally as the K20's, but it's much cheaper, has a hell of a lot of torque, and is very easy to find because nobody's really thinking about putting these into smaller cars. Motor weighs the same, it's the same size...no reason not to do it. The head's a full VTEC design, and the internals are stressed well for the power.
If I were shopping for a K motor right now, there's no doubt I'd be going for one of those two less popular motors!
(If you're looking for a K24, make sure it's out of a TSX. The K24 motors in the USDM Accord and USDM CRV are not what you want in your high performance car.)
If you insist on wanting a K20 motor then I would definitely let Leo at PasswordJDM know you want it for sure, and then let him find it for you
More k20a Engine specs from prototype racingOriginally posted by cmezoom11 on Oct/31/04
USDM = k20a2...no LSD ( RSX Type S )
USDM = k20a3...no LSD ( RSX Base Model)
JDM = k20a.....LSD ( Integra Type R 02-05)
Hope that helps
k20a swap articles:
aj racing
honda tech
