141 - 160 of 163 Posts
Discussion Starter · #141 ·
Hey Bodyman what's up? The car is down atm due to head issues (coolant mixing with oil) so just working to get it back up and running.
Studioface, finally got my J37 tb installed with your 4"CAI.
Your tb is like mine with The allen screw tapping where The sensor used to be.
I have a bit of a problem, as im having a bit of rev hang, but básically my problem is The rpms jum a lot when rolling and neutral.
Díd The tb relearn procedure without results.
Any imput?
BTW, it breathes like a beast.
I am not really looking for anything thats too much aggressive thats why I am going with the A's but for drop in cams and seeing guys making over 20whp I think thats pretty decent gains.As for the intake system the theory behind it is the more availability the air is,the faster the delivery and given the nature of these k series they love to breathe.I am sure the intake could use some fine tuning but that would require multiple tests and data logging with a flow bench and alot of trial and error.
I just made it sampler by going bigger with less bends and less restrictions.
What about their S's the supercharged cam.
Currently at 250hp
I have a perfect setup to test this j37 on a non ported rrc. I have a k20z3 with stock bottom end
Hytech header
3inch exhaust
Rrc mani
J35tb
950cc injectors
Drag cartel 2.2 cams
Super tech vt
I'm very interested in seeing what gains could be had over my current setup....
Here is a link to my dyno results with j35+rrc
http://www.k20a.org/forum/showthread.php?t=106319
Ill be doing a very similar set up, do you really need injectors that big? i was going to go for RDX ones.
hi everyone hopeing to get some help here!
so my current set up on my 07 si-
kid racing header
3'' full race exhaust
rdx injectors
e bay cold air
flashpro
stock tb
stock im...
HERE IS MY QUESTION here are the parts i have waiting to b put on-
i have a skunk 2 intake mani
hybrid racing intake 3-3.5
and i was going to go with the skunk 2 dbw tb witch was 72mm
i want to ask witch tb would b better to go with
the j35 or the j37 tb,
i saw on a different post on here that the j37 tb is only for boost or other "serious builds"
i want to know witch tb would be good for my new set up for most gains
also thinking about doing a mild cam some time in the future.
kid racing header
rdx injectors
e bay cold air
flashpro
stock tb
stock im...
I would say the j37 and ditch that skunk2 mani. I have almost all same mods.
Hybrid racing cold air intake
Skunk2 tb (wish it was j37 ive had problems with mine
Rrc
Tsx cams
kidd racing header
Full race exhaust
Sent from my SPH-L710 using Tapatalk
I have a question! I installed the the big bore throttle body but the bolts that came with it seem too short! I used my torque wrench to tighten them but it kept going in circles! I have all black bolts! Do i need the silver looking ones!
Any help at all? I dont want to run with loose screws!
Bodyman? Is there a chance they gave me the shorter screws??
keep this thread alive, we have sold more and more J37 throttle body kits so Im sure people will want to read on here
