1 - 17 of 17 Posts
Can anyone explain to me what the difference is between the JDM type R motor and the US type S motor?
From what I know almost everything is different.
The valve train the cams, basically the whole head.
The intake mani, and the header
The pistons, how about the crank and rods?
What about the block?
So from what i know almost the whole motor is, but specifically would you need to replace to get the Type S motor to type R specs?
Discussion Starter · #2 ·
Is the intake manifold flange the same pattern on both motors?
Different pistons, Head flows more, Manifold flow more, Probably a stronger crank, and stronger rods for a fact, higher comp. pistons.
No difference in the block.
So then the flanges on the intake mani would be the same, although the type R's (K20A) intake mani flows better.
Jon V, its not the flanges its the design of the Manifold.
I am planning on making a set of ITB's for my R motor, but I am going to pick up a type S intake mani to hack the flange off of :wink: . So as long as the flanges are the same thats all i am worried about
?? why dont you buy ITB's.
Discussion Starter · #8 ·
I could make some for a 1/4 or 1/2 the price and they will work exactly the same, if not better. All I need is a set of Hyabusa throttle bodies, some custome runners, and some velocity stacks and I'll be good to go :roll: Might cost me 500-600 w/labor, compared to what like 1500-2000 for a Brand name?
There worth there price but do what ever you want it's not my car.
Discussion Starter · #10 ·
If the head on the K24 is the same design as the K20 then I should be able to drop my ITB set up on the K24 head right?
I heard something about the TB being different, but if I am replacing it I am not sure of it's importance.
Re: k20a-h22a swap?
eltegre88 said:
i was looking at motors and the h22a type-s has the same power and torque as the k20a type-r, but costs about $2,000 less. is it possible to drop this into an o2' rsx?
If anyone ever dropped an H22 into an RSX I would slap them
The K series is better in every way and has much more potential to make power.....the 2000 savings would quickly disappear once mods began and you noticed the K made more power....
H22's belong in preludes and accords
Civics/Integras should use B/K motors
But people will do anything so maybe someday someone will drop an H22 into an RSX and we call all have a good laugh
1 - 17 of 17 Posts
