310cc will be sufficient for a stock type build with OEM redline. Keep an eye on your injector duty cycle in K-pro. If you start getting close to 90%, and want more power, plan on upgrading them.
This is a k24a1 longblock or a frank build?3 days still waiting..
K24a1 (All original Crv sensors)type s harness do pins need to be changed in order for vtc spool sensor to work properply noticed part number are diffrent???
Help me out k20
What order do i repin them do just look at the crv harness an see where the wire colors go in which pin. I got a code of vtc malfunction and I'm guessing wiring is diffrent on type s harness as the part number is diffrent I need some guidance.please thanks for the reply man.This is a k24a1 longblock or a frank build?
Just de-pin the clips from the type s harness and re-pin with the CRV ones and you should be good to go.
If you are using a K20A2 wiring harness, then you will need to use the K20A2 sensor.I read one of the olDer post u stated crv tps and rsx type s are diff I'm running a rsx type s tb and imo on my k24a1.should I buy the type s tps ?
If the part number is different, the sensor is different. Change the sensor to match your wiring harness and ECU.3 days still waiting..
Help me out k20
Yes, you need a k20a/k20z knock sensor. For the CPS, either K24A1 CRV IIRC or the k20a2 for sure. For simplicity, id use either of the two.I saw a few guys on here ask the same question but haven't seen much of a definite answer. Just trying to clear things up for myself before I go buy the part. I have a K24a4 (element) bottom end and a K20A2 head. I got the K24 complete with all the sensors and harness. From my understanding, all the sensors from the K24 head should swap over to the K20 except for the knock sensor and the k24 cps plug just needs to be re pinned onto the k20 harness. Is this correct? I won't need to purchase a k20 vtc solenoid or any other sensors? All help is appreciated. Thank you
Have you double checked that the sensor is clean?Just called up honda and i asked what was the part number for vtc on a 02 he said rbb i said that cant be cause i have a rbb in there now and it dosent work.So im ganna order the type s part number PNB?
:google::google: <---Use that to search, very helpful.Just called up honda and i asked what was the part number for vtc on a 02 he said rbb i said that cant be cause i have a rbb in there now and it dosent work.So im ganna order the type s part number PNB?
It is also in the first post of this thread =p:google::google: <---Use that to search, very helpful.
The Type S VTC part # is 15830-PNC-003 (VALVE ASSY., VTC OIL CONTROL)
