1 - 20 of 31 Posts
#2 said:
Yes and yes.
You can use either B or D series temp sender/fan switch. My Hasport piece with sensors installed:
So if you use this piece you just put it in line, befor the coolant gets to the radiator? Then you have to plug up the holes that everyone else is using?
hole in rad for sensor- if there is one...
nad the other sensor usually goes?
and with the hasprot piece you can use the older D or B series sensors?
Yes, you install it inline on the upper radiator hose. If you are using a DC5/EP radiator you can get an automotive drain plug (12 x 1.25 thread pitch) for the sensor outlet in the radiator. If you decide to run the sensor in the DC5/EP radiator, i believe Hasport makes the billet adapters in 3 versions. Coolant temp sensor only, Fan switch only, and the dual sensor piece pictured.
The temp sensor on the K series is located on the head where Supafly has a B/D series sensor in his picture. It is not useable. Thus why you have to run a B/D series sensor.
I am using the stock sensors off my D15b8. So yes either B/D will work.
I will try to get some pics tonight to further explain what i'm talking about. :)
I think I pretty much got it. Thanks
You just can't use the K temp sensor, period. But you can put the B/D sensor in it's place... :up:
1 - 20 of 31 Posts
