1 - 20 of 36 Posts
Tein Now Available At CorSport
TEIN was born in rally. TEIN’s technological advancements go hand in hand with motorsports activities. Motorsports is crucial for TEIN to elevate its engineering and to refine its ideal suspension. TEIN embodies the famous ‘Laboratory on Wheels’. Utmost technology comes from the competition fields where winning requires competing for every tenth of a second. All the valuable data obtained from competitions are refined and poured into all TEIN products built for the street.
TEIN keeps challenging to competitions held all over the world. There are races that compete for one thousandth of a second, have big jumps at 170km/h and/or run on extremely cold icy road or on scorching hot desert. Technology and know-how cultivated in worldwide competitions under such severe conditions is poured into each and every TEIN shock absorber. Superior performance and superior quality for your shock absorbers. TEIN keeps evolving, forever and ever.
CorSport USA.
Discussion Starter #4
06-11 Honda Civic Si Tein S.Tech Springs
Tein*Stylish Spec Dress Up Master S.Tech Springs
TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
Made in Japan under strict quality control standards and developed by highly trained suspension engineers.
Additional Features
• Chrome Vanadium SAE9254V Construction
• Progressive Spring Rate Design
• Includes Silencer Rubber on certain applications
• Green Powder Coat Finish
• Developed to be used in conjunction with OEM or OEM replacement dampers
• 1-year Manufacturers Defect and Sag Warranty
Covers over 5mm sag, breakage, deformity, and noise.
Does not cover powder coat finish and rusting.
Contents of Damper Kit:
Individual Springs × 4
Main Spring × 4
Some applications include TEIN Silencer Rubbers
Warranty Information and Bump Stop Reference Guide
2 TEIN Decals
Ride Height (F) -1.38in (-35mm)
Ride Height (R) -1.26in (-32mm)
Spring Rate (F) 230lbs/in (4.2kgf/mm)
Spring Rate (R) 270lbs/in (4.9kgf/mm)
CorSport USA.
Discussion Starter #10
05-06 Acura RSX Tein S.Tech Springs
Additional Features
Main Spring × 4
2 TEIN Decals
Ride Height (F) -1.46in (-37mm)
Ride Height (R) -1.69in (-43mm)
Spring Rate (F) 310lbs/in (5.5kgf/mm)
Spring Rate (R) 490lbs/in (8.8kgf/mm)
CorSport USA.
Discussion Starter #12
02-05 Honda Civic Si Tein Flex Damper Kit
Tein Control Master Type Flex Street/Track Damper Kit
TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
Additional Features
• Steel Construction
• Twin Tube internal construction
• Ride Height adjustable via threaded body and spring seats
• 16 way adjustable dampers, compression and rebound combined
• Pillow ball upper mounts for increased steering feel
• Upper camber adjustment on front for strut type vehicles
• Larger piston diameter for strut type front and rear (22mm)
• EDFC (Electronic Damping Force Controller) compatible
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
• 1-year Manufacturers Defect Warranty
Adjustable Shock Absorber × 4 Bump Rubber × 4
Main Spring × 4 Hook Spanner × 2
Some applications include helper springs Dust Cover × 4
Pillow ball Upper Mount × 4 Instruction Manual × 1
Lower Spring Seat × 4 Sticker Sheet ×x 1
Seat Lock × 12
Upper Mount*w/ Camber Adj
Damping Force*Adj.
Full*Length Adj.
EDFC Comp
Twin Tube*Design
Ride Height Range (F)*-14.0 / -0.55 to -66.0 / -2.6
Ride Height Range (R)*-37.0 / -1.46 to -71.0 / -2.8
Spring Rate (F) 670lbs/in (12kgf/mm)
Spring Rate (R) 780lbs/in (14kgf/mm)
CorSport USA.
Discussion Starter #14
Steel Construction
Discussion Starter #15
02-06 Acura RSX Tein Type N1 Damper Kit
Tein Super Racing Spec Circuit Master Type N1 - Race Use Only - W/ Front Lower Bracket - W/OUT Spring (Sold Separately)
**Sold individually. Pillowball upper mounts, and springs need to be purchased separately.**
Type N1 is our exclusive racing model application which encompasses TEIN's technological innovations and extensive racing experience. The N1 damper is a mono tube design available in either aluminum or steel construction. Features full-length adjustment for individual adjustments of spring pre-load and damper length. Separate 20 x 20 way compression and rebound adjustment for fine tuning. The stroke and valving have been specifically designed for circuit racing conditions to provide maximum grip. TEIN highly recommends the use of TEIN racing springs with type N1 dampers. *For Race Use Only
Made in Japan under strict quality control standards and developed by highly trained suspension engineers. *
Additional Features
• Available in Aluminum or Steel Construction in meet various class regulations
• Mono Tube internal construction
• Designed to be extremely lightweight
• Inverted design for strut type front and rear
• 20 × 20 way adjustable dampers, compression and rebound separately adjustable
• Anodized green color
• Available for Overhaul
Adjustable Shock Absorber × 1
Lower Spring Seat × 1
Seat Lock × 2
Bump Rubber × 1
Instruction manual
Damping Force*Adj.
Full*Length Adj.
Mono Tube*Design
External*Reservoir
Ride Height Range (F)*-72.0 / -2.83 to -103.0 / -4.06
Ride Height Range (R)*-67.0 / -2.64 to -90.0 / -3.54
Spring Rate (F) 1008lbs/in (18kgf/mm)
Spring Part # (F) RS180-B1150
Spring Rate (R) 1570lbs/in (28kgf/mm)
Spring Part # (R) RS280-A1100
CorSport USA.
Discussion Starter #18
02-05 Honda Civic Si Tein High Tech Springs
Tein*Guarantee Spec Luxury Master High Tech Springs
TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. Designed and tested in North America to be used in conjunction with OEM or similar shocks for excellent ride comfort and slightly increased handling. The line is produced with Vanadium (SAE9254V), which is durable, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more attractive appearance, added performance, and excellent comfort. Includes a one year limited warranty.
Additional Features
• Gold Powder Coat Finish
Main Spring × 4
2 TEIN Decals
Ride Height (F) -0.79in (-20mm)
Ride Height (R) -0.67in (-17mm)
Spring Rate (F) 260lbs/in (4.6kgf/mm)
Spring Rate (R) 480lbs/in (8.5kgf/mm)
CorSport USA.
1 - 20 of 36 Posts
