1 - 2 of 2 Posts
hi,
unfortunately i have tein basic kit on my k20r swapped EK right now. spring rates are so low and i will be going to a drag event next week.
spring rates are: 6.0 kgf/(mm) front and 3.0 kgf/(mm) rears.
i don`t have time to order new spring with new rates from US because it takes 20 days to arrive to me.
i searched and foundout that some people use Spring Rubbers at rears. i don`t have time for ordering them too. can i use something else as Spring Rubbers? if yes what can i use?
can i try to swap the springs at front to rear?
thanks
buddy of mine uses these on his low 10second integra. the rear is raised to the point that they started compressing the rear springs with the collars. car does not squat at all whatsoever.... raise the rear up as high as you can and you should be ok for an event :up:
1 - 2 of 2 Posts
