1 - 20 of 40 Posts
Corsport is now offering Techna-Fit Stainless Steel Brake Lines for a large majority of applications!
All Categories
All of Techna-Fit's assemblies are assembled in-house, meeting D.O.T. Certification. Techna-Fit brake line kits come complete with all of the fittings and bolts for easy assembly.
One advantage is that Techna-Fit lines reduce volumetric expansion. Over time and under continuous use, OEM rubber lines can swell and expand, exposing the driver to brake fade. The rubber cover is also vulnerable to attacks from the ozone layer (rubber deteriorates and causes failure). In extreme applications (auto x, racing, hard driving) rubber hoses might be susceptible to debris, thus causing failure. Stainless steel hoses provide some added protection from these issues.
At Corsport, Shipping is always free to the lower 48 states.
Discussion Starter #9
02-05 Civic Si Techna-Fit Stainless Steel Clutch Lines
Techna-Fit Stainless Steel Clutch Lines - 1 single Stainless Steel Braided Clutch Line
Techna-Fit Stainless steel clutch lines are manufactured to DOT specifications. The stainless steel construction eliminates 'ballooning' associated with stock rubber lines, making for improved clutch pedal feel and better fluid transfer. This is an excellent item to replace at the same time as a clutch install.
All Techna-Fit hoses are available with a PVC cover, which gives added protection from flying debris; it also gives some abrasion protection from the line rubbing on suspension parts, in extreme braking conditions, with full compression (most movement of line).
All Techna-Fit's factory assembled line kits are backed by their lifetime warranty.
Other available colors: Clear/Silver (standard), Black, Blue, Charcoal, Red, Smoke, Green, or Yellow PVC covering
CorSport USA.
Discussion Starter #16
02-05 Civic Si Techna-Fit Stainless Steel Brake Lines
Techna-Fit Stainless Steel Brake Lines - 1 set consisting of 4 Stainless Steel Brake Lines
Techna-Fit brake lines are made using teflon hose. The teflon hose has an extruded teflon core, with an outer stainless steel braided wire covering. The chrome or zinc plated steel fittings are then permanently crimped on each end.
All kits are standard with clear PVC cover hose and chrome fittings.
CorSport USA.
1 - 20 of 40 Posts
