1 - 20 of 306 Posts
So I've had my TW FG since Dec last year. Santa decided to drop me off 2 bundles of joy which prompt me to let go of my Eg. The second gift being my 1st baby girl, well first child period so can't be upset about those kind of priorities.
Anywho here's a recap of my Eg and plans/Pics of the new project:
Picking her up from Tucson how I purchased
Decided to spray the full car in pearl blue
Had this in her but decided I'd do a heart transplant
With this :dance: K24A1 Which ended up getting a TSX K24A2 Head later
Out
IN
Decided I didn't like the red anymore so did this along with changing the IM(RRC), head(K24A2) and routing of a few things.
Then long story short daughter was born and wifey needed a new car so let go of it.
On to the the Fg :cool: and in the garage for the first time
And bye bye Pin Stripe/Pretty much how she looks today
When I sold the Eg I took the k24 out as I figured it would fit nicely with the heavier SI :driving: the heart will live on in my Fg, built better and stronger! So the RRC made it's way onto the z3. Along with flash pro, J35 TB, and Aem/custom Cai intake system.
Changing the Tbs: J35 on the left with IMT fitting for vacuum.
J35 Pac-maning the Oem Si one.
Flash Pro: Uploaded the Aem cold air Kal for now
Then, got some toys in the mail. Retro Solutions LLC Digital 55w HID Kit
Also bought Mini H1 projectors and relay harness from TRS
Went to work
Dinners In The Oven!
Painted the reflector with a Hi temp Blk
Projector in
Mounted back on the car and testing
Cut off
Finished product
I got these in the mail courtesy of Scott and HPT AutoSport: Supertech 87.5 Bore 12.5:1 Comp Pistons
The star of the show: out and ready to be broken down.
Decided to install my Rdx injectors and paint my intake tube to blend a bit better.
De-pinning the injector clips
And all installed on the fuel rail
Clips in place and all installed back on the manifold
Then decided since I was wrenching and bumper was off I'd paint my intake tube textured black. Was also re-doing my hids at the time
Will have alot more updates of course as I buy more parts and build the block and head:up:
^ Preciate it :up:
Got the motivation to start breaking it down Sunday:
Ep3 trans is off finally-For sale also :silly:
Flywheel will be making it to the Z3 trans/Clutch im not so sure about yet
K20A2 cams I was running
Just about ready for the engine stand
Once I break it down fully will be sending it off to the machine shop :dance:
:up: I love Taffeta White!
Great progress so far.
Discussion Starter · #8 ·
Discussion Starter · #11 ·
Mini H1 bowl are not made for 55w set up, it can burn the bowl. I would stick with a 35w set and 4300k bulbs. BTW very nice build.
Thx!
Read about that in a few diffrent places. These bulbs are suppose to put out the same amount of heat a 55w halogen bulb does but time will tell. If it does kill the bowl I'll replace with S2k or Tsx projectors.
Thx!
TSX= overrated. The mini h1 will out perform them. I would go with rx330 with clear lens. They are like s2k little brother. If you want a boss set up, I would go rx350, they out perform the tl and they are easier to mount in the 8thcivic headlight.
Discussion Starter · #14 ·
^ Thx! Trying to save up some cash to drop a set of SVM 312s in but need to move a few more of the parts I have still around from my Eg.
The Eg is up and running now just need to smog and register. I will probably have it done here within the next month. I will swing by when im legit. Clean build so far good luck.
Discussion Starter · #16 ·
Preciate it Cam, glad to see her in good hands :up:
You should post a pic in here also.
Discussion Starter · #18 ·
Was able to make a bit of progress this weekend taking apart the K:
Got it up on the stand/Removed water pump housing
Crank Bolt not an issue this time thankfully :silly:
Cover and chain off
Cam Caps and cams removed
Box O Parts: Will be posting the K20A2 Cams up for sale also
And the head is off, arp studs exposed
PPA Pistons that will be exiting the block
Will continue to break the block down and hopefully get it to the machine shop soon. Also made a decision about the cams I'm going to run in this setup then pulled the trigger......:rolleyes:
SVM will be my cam of choice, in the 312 variety:fkya: Will post pics once they arrive!
<a href="http://www.flickr.com/photos/[email protected]/7549654964/" title="My eg by Eg SIR, on Flickr"><img src="http://farm9.staticflickr.com/8143/7549654964_7d5d3f2de6_b.jpg" width="1024" height="768" alt="My eg"></a>
Here is the Latest.
1 - 20 of 306 Posts
