1 - 1 of 1 Posts
Hi, I have an 03 and I just swapped in an ITR gauge cluster and everything works fine but the SRS light is on. I tried to clear it with the paper clip trick and no joy. It’s the 15-2 error. If I swap back in my OEM cluster I can clear the code and no problems. Since the ITR never had side air bags is there something missing in the cluster that’s causing the SRS light? Do I need to add in a resistor some where? I’m not having any luck with the search function either.
Thanks
1 - 1 of 1 Posts
