1 - 4 of 4 Posts
Can anyone tell what transmission I can use to replaces a Honda Element 2004 manual awd 5 speed transmission the element transmission are too expensive
Super Moderator
2002 DC5 Type S
welcome to the forum.
Super Moderator
2002 DC5 Type S
the link i posted said they are interchangeable. I do see that the 2004 transmission cases are different part numbers. Hopefully that link will provide you with some decent info, try searching further here for info.
The VSS on the CRV transmission is gear driven off the differential, on the Element it is the high frequency type that uses 3rd gear. If you can find a converter to fix the VSS you could use a CRV transmission.
The AWD 5 speed from the Element and CRV are roughly the same price and both fairly expensive. I would guess around $800 for a cheap one.
1 - 4 of 4 Posts
