321 - 340 of 346 Posts
correct, the RBC or RRC bolts onto the TSX head just the same, no mod needed, we keep both instock for anyone, with any adapters and gaskets to go with it, all from one place!, pm me
Finally going k-series in my EG race car. I have a k24a2 w/ rsx 5 speed tranny.
Im going with the innovative mounts. The question I have is do I need a k24 crv passenger side bracket or mount? Im also in the process of putting my RSX-S harness(02) on the motor and there is a sensor all the way near the crank pulley that the plug wont fit on the sensor. Can that sensor come from a RSX so it will be plug and play for my harness?
Parts still needed:
type-s ECU(02-05)
im piecing together a k24a4/k20 build...i know froth said that which ever motor the starter/alternator come from doesnt matter, that either ones will work, however ive also heard that you need certain ones for a frankenstein build, and with looking up part numbers for the starters, they are different.
just wondering if anyone had any clarification as to specifically which ones frankenstein builders can use, or if it doesnt matter.
also wanted to say thanks for a great guideline...as i piece my build together, this will come in handy
thanks,
- ian
Okay guys I'm really new to this forum. And I've been doing a lot of research.
I don't know exactly if this is the right thread for this. But if anyone of you could
Help me out on this. I want to order an fd2 type r k20a further built from spoons mechanics with 11:9 compression ratio. From nengun.com. For building a complete badass Na setup. Would it be the right thing to do. Or just get any ep3 or dc5 k20a. Coz it says that the fd2 type R k20a has 215Nm of torque which is more then the other k20's in the market excluding the blueprint engine from spoon the one I was talking about earlier which has sharper acceleration and high mid range and bottom end torque. I really want to pick the right motor. So please help me on this. I'm planning to put this in a 95 civic eg. And also tell me that buying an engine of $6k really worth it. Coz other k20's also cost around this much.
Hi I'm new and I'm looking to doing full k20 swap in my track eg. I was planning on buying a full ep3 and strip all parts need for swap to save money on buying the mounts and so on.. Is it possible to use all ep3 parts onto my eg shell? Don't mind welding or fabricating parts as we are doing a big build with lots of welding. ;)
Like the title says, I'm tired of seeing all the "what do I need for this" etc. posts and I really just hate saying "Search, you'll find answers." While the answers ARE out there they aren't 100% easy to find. I found them on the site, but I've also looked for a while.
This is what you want, THE K20/24 SWAP PARTS LIST. Items are also loosely categorized and are meant to be the cheapest possible way to complete the swap. Please keep in mind this may not be 100% accurate to what you want to accomplish but it's damn close! Here it is!
ENGINE/TRANNY (All gaskets/seals are considered "known to be needed" items)
K-series engine(K24/K20)
K-series tranny(Type-R/RSX-S/RSX Base)
K-series engine harness(RSX-S 02-04)
K-series charging harness(RSX-S 02-04)
K-series Alternator(For Engine of Choice)
K-series Starter(For Engine of Choice)
K-series ECU(RSX PRB 02-04) Plus Hondata K-Pro(Or JDM K-series ECU)
CRV Passenger side engine mount(needed for non-CRV K24 swaps)
Header(R-crew/DC/SSR)
Clutch/Flywheel(RSX-S)
RSX Type-S Oxygen Sensor(Primary)
RSX Type-S Knock Sensor(Only if not using RSX-S engine, Or repin stock Knock sensor)
RSX Type-S Clutch Slave Cylinder
RSX Type-S Halfshaft
RSX BASE Axles(For EG only, Swap inner joints) Or...
RSX-S Axles w/ B-series Outers(For EG again, Also rec. swapping inner joints)
RSX Type-S Throttle Body(Or Accord throttle body, depending on engine/intake)
RSX-S Intake Manifold(Or RBC/TSX/Accord)
Karcepts Throttle Body Adapter(only if using RBC)
Engine Mounts(Hybrid/Avid/Hasport)
Harness Conversion(Hybrid/Hasport/Sparkks)
Clutch Line(Hybrid Racing)
RADIATOR/COOLING (This is for using stock radiator)
Hasport Billet Hose Adapter(For Stock B/D series Fan switch/coolant temp sensor)
Perma-Cool PRM-19120 11"x10" Fan
TOP Rad Hose - RSX Type-S Top Hose(for EK/EG)
BOTTOM Rad Hose - 99-00 Civic Si Top Hose(for EK/EG)
SHIFTER PARTS
Karcepts Shifter mounting kit
RSX Type-S Shifter Box
RSX-S 02-04 Shifter Cables
Shift Parts to Connect Cables (OEM, easy)
EXHAUST PARTS (Must be custom welded, Can substitute for 2.5")
Kteller 3" Stainless Piping
3" in/out Muffler
Catalytic Converter if you choose to use one.
FUEL SYSTEM PARTS (Using stock fuel rail, minimum costs)
(www.summitracing.com)
EAR-991945ERL - Converts OEM fuel filter to -6 AN fitting
EAR-165056ERL - Converts OEM fuel rail to -6 AN fitting
RUS-610020 x 4 - Straight -6 AN Hose couplers
SUM-220166N x 3 - Straight cut -6 AN to -6 An hose, Ports on FPR.
RUS-610160 - 90 Degree -6 AN Coupler from fuel filter to FPR.
RUS-632070 - 10 feet -6 AN Hose
AEI-13109 - Aeromotive Fuel Pressure Regulator.
Walbro 190/255lph Fuel Pump(It's cheap, and worth it - www.hybrid-performance.com)
IF REMOVING POWER STEERING(with no A/C)
EP3 Idler pulley/bracket
Manual Steering rack, Or Loop P/S rack
K24 = 52" Serpentine Belt(works perfectly on mine)
K20 = 50.5" Serpentine Belt
IF KEEPING POWER STEERING (No A/C - With a current P/S rack)
K20 PS Pump
Jackson Racing Pulley - P/N: 052-154 (This will clear an EG hood with K20 swap, no hole...only cutting.)
52" Serpentine Belt(only for K20 - K24 = Unknown?)
02-04 RSX High pressure hose
3/8" I.D. hose
Oil cooler from Perma-Cool Industries P/N:1007 (for P/S fluid return line)
Fluid NEEDS:
POWER STEERING FLUID - 2 Bottles
DOT3 Brake fluid - 2 Bottles
Coolant 50/50 Mix - 2 Bottles(3 to be safe/cover leaking or spillage)
MTF - 3 Bottles
OIL - 6 Quarts
RANDOM HOSES (Not totaly acurate for ALL swap configurations, keep in mind O.D. and I.D. measurements)
10' 3/16" I.D. Hose (possibly not all swaps)
10' 1/4" I.D. Hose
10' 3/8" I.D. Hose
5' 3/4" O.D. Hose
5' 1" O.D. Hose (possibly not all swaps)
MISC BOLTS/Parts (This is mainly used if you buy Engine/Trans apart from one another)
90034-P10-A01 X 6 clutch bolts
90011-PNA-B00 x 8 flywheel bolts
22103-PNA-003 pilot bearing
95701-12060-08 x4 tranny bolts
95701-12085-08 x 2 starter bolts
90027-PND-A00 starter bolt long
90025-PNA-000 bolt
95701-08055-08 x 2
90008-PNA-000 x 2 alternator bolts
90008-PPA-000 bolt
21351-PNB-000 cover for tranny to connect k24a with k20a2 type s tranny(only K24)
95701-06012-08 x 3 bolts
MAIN SITES TO USE:
https://www.hondapartsdeals.com/
http://www.thehondapartsstore.com/
http://www.acuraparts247.com/
http://www.acuraoemparts.com/delray/jsp/home.jsp
http://www.summitracing.com
http://www.jhpusa.com
http://www.hasport.com
http://www.hybrid-racing.com/
http://www.karcepts.com/
http://www.rockauto.com/ (cheap hard to find OEM parts)
http://www.rcrewracing.com
http://www.sixsigmaracing.com/home.htm
http://www.motors.ebay.com/ (you can save a lot if you look for deals)
This should be absoloutley EVERYTHING you need to complete a K20/24 swap, Minor variances will be there as this list is meant for an EG only because It's what I own :silly: However it should be 95% of what you need for EK/DC2 aswell.
That should be it, Correct me if you see something wrong. Hopefully this stops all the "Zomg what do I needz" posts...
I have a 02' dc5 type s... I wrecked the car and wanted to swap the k into my 99' Gsr... What do I keep from the dc5? Has bolt ons and kpro v3... Also, my Gsr has Jdm 36mm... I heard I can use my Jdm axels... Anything will help... Just need to know what I can keep and use during the swap and what I will need...
Thanks for reading and please anything will help... And yes I've googled but havnt found anyone that totaled a dc5 and wanted to swap over to the dc2... Thanks!!
duct tape and zip ties
Axles from the 8th gens and rsx are 36mm. I believe the list a category for swap no swap inner axle options. Or swap the axle things as described above.
Keep the kpro, engine harness, and probably a lot more.
SHIFTER PARTS
3" in/out Muffler
K20 PS Pump
3/8" I.D. hose
Fluid NEEDS:
MTF - 3 Bottles
OIL - 6 Quarts
10' 1/4" I.D. Hose
10' 3/8" I.D. Hose
5' 3/4" O.D. Hose
90025-PNA-000 bolt
95701-08055-08 x 2
90008-PPA-000 bolt
MAIN SITES TO USE:
This is a great thread for a newbie like me, thanks. Question: What is the going rate for a K-series install (probably early 2000 motor) engine and install? Are USDM swaps smog legal? How many headaches did you encounter with refs, passing smog, engine fits, etc.? What do you think of B16 or B18 swaps?
Call up a shop that you want to have them complete the swap, some have a simplified rate for the work. You should research the requirements for your area, in terms of the smog aspect; although, I have read most pass often.
I always have, and will always have only K series in my fwd honda's; you are on k20a.org, not b-whatever... so B series are irrelevant.
What about a throttle cable?
Karcepts sells throttle cables for the swap, think I ended up getting the GSR cable and bracket they sell, but that was years ago and I dont remember. Ktuned also sells a throttle cable and bracket too, for swaps.
