1 - 1 of 1 Posts
How is it going everyone, I just wanted to put a thread together about what kind of suspension people are running. I'll just start with my car. If you could post what you are running that would be awsome. Thanks guys.
92 cx hatchback
current set-up:
Ground control w/ koni's
Ground control upper mounts (+ 1inch of travel)
Omni rear control arms
94 Integra complete suspension conversion
Skunk2 upper a-arms (not recommended)
Suspension techniques 22mm front sway bar
Stock Integra rear sway bar
Front spring rate 8/400lb
Rear spring rate 7/450lb
Set-up soon to come
88-91 crx front koni(they are shorter by a 1.5inch)
Front spring rate 7/500lb
Rear spring rate 7/550lb
Cp industries traction bar
Type-r front sway bar
1 - 1 of 1 Posts
