1 - 20 of 23 Posts
Brockway Dgauge :up:
I am offering these to you special people for a rediculous price!! $359 shipped with your choice of the Shift light or a Micro mount!!!
Limited time only!!!! this wont last long.
http://www.k20a.org/forum/showthread.php?t=99200
The DGauge is a digital multi-gauge that plugs into the diagnostic port on most 1996 and later Asian, European and some US vehicles and displays real-time engine data on it's color TFT LCD. Through the selection of one of 3 different screen modes, you can monitor 2 or 4 user selectable parameters at a time. As many as 25 different parameters are available for viewing, depending on vehicle support and 7 parameters via external sensors. Exceptionally easy to set up and operate. With unmatched performance and reliability, the DGauge offers the most advanced technology in engine monitoring.
100% compatible with all K-Series applications utilizing the factory ECU.
100% compatible with K-Pro. Monitor A/F ratio, engine temp, boost and more.
http://www.brockwayengineering.com/
Optional shift light $27
Optional Micro mount $30
OBD Parameters
RPM (Engine RPM)
CLV (Calculated Load Value) %
ALV (Absolute Load Value) %
STF (Short Term Fuel Trim) %
LTF (Long Term Fuel Trim) %
IGN (Ignition Timing) °
TPS (Throttle Position Sensor) TPS
MAP (Manifold Absolute Pressure) kPa
BP (Boost Pressure) kPa or psi
MAF (Mass Air Flow) g/s
ECT (Engine Coolant Temperature) °F or °C
EOT (Engine Oil Temperature) °F or °C
IAT (Intake Air Temperature) °F or °C
AAT (Ambient Air Temperature) °F or °C
O2 (Oxygen Sensor Voltage) v (Bank1 and Bank2)
AFR (A/F Ratio) (Bank1 and Bank2)
ALC (Fuel Alcohol Level) %
VSS (Vehicle Speed Sensor) mph or km/h
BAT (Battery Voltage) v
FRP (Fuel Rail Pressure) kPa or psi
GR (Gear Position) 1,2,3,4,5,6
* Some parameters not available on all vehicles. See the Parameters page for a list of available parameters for different vehicles.
AFR (A/F Ratio)
EGT (Exhaust Gas Temperature) °F or °C
OIL (Oil Pressure) kPa or psi
FEATURES
• 3 screen modes that allow the user to select the parameters displayed.
• 2 or 4 "Gauge" screen layout.
• Selectable color for each "Gauge".
• Speed and Temperature can be displayed in Metric or English units.
• Pressure can be displayed in kPa or psi.
• Reads and clears diagnostic trouble codes (DTC's).
• Turns off check engine light (CEL).
• Displays boost on vehicles equipped with a MAP sensor.
• Displays A/F ratio on vehicles equipped with an OEM wideband O2 sensor.
• 2 external sensor inputs.
• Programmable shift light output.
• Adjustable Alerts (ECT, EOT, EGT, MAP, BP and OIL).
• External Alert (OIL and EOT).
• Adjustable LCD brightness.
• Fast update rate.
• Data output for logging.
• Updatable Firmware.
• Simple Plug and Play installation with included Data Link cable.
• Advanced high reliability 3" TFT LCD. Readable in direct sunlight.
• Automotive grade components used throughout.
• Compact size (5.2"x 2.2"x0.75"). Includes mounting brackets.
• A/F ratio conversion for Honda/Acura K20 engines built from 2002 to 2004. Vehicles with these engines have wideband A/F sensors but do not report the A/F ratio via the standard PID for A/F ratio and must be converted from the O2 sensor voltage. Accuracy is within a tenth of a point (0.1) from 11.5:1 to 15.5:1 A/F ratio. It will read richer and leaner mixtures, however the conversion is less accurate as the A/F ratio moves out of this range.
Re: Suuporters get DGauge special deal!!!
I think we need to give some more info Ryan. Since we have gotten our hands on these, everytime we discuss, the response is always wtf is that?
We want these in your hands, so you guys can get the convo's going, and really try to bring Brockway the credit it deserves.
well that was my plan, Id like to have as much info in the threads as possible and any questions should be posted and . Thats why its easy to discuss in a thread here or the one in the link. Id rather this thread or the other have lots of activity and opinions, facts, reviews etc...
spelling owns Ryan.
and its not in the AFH forum so I cannot fix it.
As a suuporter I think this is a great deal! Would this work in my Sti?
as soon as the vid is posted we will post here and the fb page. 500 whp subie on awd dyno using dgauge
i can take a vid of mine on way to work and post it tommorrow:up:
I saw the set up in Stans car and it convinced me. I've always thought the screen might be too small, but i think its just right. seems easy to see at a glance and with the shift light it should be great for the track car.
Been There Done That
is this deal still good? just when i thought i was done buying stuff from you guys for a while i find this thread. :silly:
how can you mount these? is the micro mount the only option? or does Brockway offer like a generic style mount or something?
no you can do all kinds of stuff.
micro is easiest.
you can do custom install in dash or console, glovebox, something under dash, quite a few options.
1 - 20 of 23 Posts
