1998 Honda Civic cx
65,000 miles on body, less then 400 on build
Mechanical mods
-Bensons sleeved /o-ringed B18c (83.5mm bore)
-JE pistons 10.0:1
-Crower rods
-Micro polished crank
-Moroso oil pan
-Mocal oil cooler
-Full-Race exhaust manifold
-Tial 46mm wastegate
-Tial 50mm bov
-HKS T51r turbo (custom spec.)
-Spearco intercooler core (28”w 10.5”h 3.5”d)
-Meziere electric water pump
-Fluidyne radiator
-Fully ported and polished head
-JUN stage 2 cams
-JUN valve springs/ titanium retainers
-JUN cam gears -
-ARP studs
-SX fuel pump/filter/ fpr
-RC Engineering 880cc injectors
-Golden Eagle intake manifold (port matched to head and throttle body)
-Golden Eagle scatter shield
-BBK 70mm throttle body
-Place Racing motor mounts
-Custom 3-inch exhaust w/ v-band flanges, HPC coated
-JUN titanium muffler
-Custom PCV system into exhaust
-All braided stainless lines (fuel, vac. Etc.)
Driveline
-Driveshaft shop stage 5 axle/hub
-ACT xtreme duty pressure plate
-Clutchnet 4 button race disc
-JUN lightweight flywheel
-Quaife LSD
Suspension/Brakes
-Tanabe sustec pro coilovers
-Cometition Engineering Traction system
-Suspension Techniques sway bars
-SRR rear lower control arms
-Mugen front upper strut bar
-SI rear disc conversion
-Powerslot rotors
-Hawk pads
Inside
-Sparco Flash 3 steering wheel w/ quick release hub
-Sparco Evo seats
-Sparco 3 inch harnesses
-Moroso switch panel
-Motec PLM
-A’pexi AVC-R
-AEM EMS
-Defi gauges
-Custom 8 pt chromemoly roll cage w/swing outs (NHRA certified)
Outside
-JUN rear spoiler
-CWEST front bumper
-J-SPEC carbon fiber hood
Wheels
-Volk TE37 15x7 BLACK (street)
Tires
-Front 225-50-15 BFG Drag Radial, and 225-50-15 Bridgestone S-03
-Rear 205-55-15 Bridgestone S-03
This is off the top of my head, I am sure I missed something.
$21,500
Thanks
Anthony
The car made just under 600hp @ 22psi on a mustang dyno
When its tuned to 30psi it should be close to 700
The car ran an 11.0 @129 (22psi) in a shakedown pass with some old 22inch slicks
