1 - 4 of 4 Posts
How much HP can the stock injectors support without having any problems??
I'm interested, cause my car is going back on the dyno in 7or8 days and was wondering if I need to upgrade the injectors before I get there.. I hoping to be running 240whp from my JDM ITR K20A, will the stock injectors be to close to being maxed out??
They'll be fine up untill you run a turbo and more like 280-300 whp. You should be more worried about the pump before injectors...
PS- are you using the R injectors or S/base injectors?
Vince
Injectors
- Use saturated injectors (12 ohms) like the new 440 and 550s from RC Engineering
- Stock RSX Type-S has 310 cc injectors
- 550 cc injectors at 50psi fuel pressure can handle approximately 320-350 whp
- The Honda stock fuel pump is good for 250-290 whp
1 - 4 of 4 Posts
