Long story short I believe I drove the car with low oil to no oil after I shoveled snow off it about a month ago.
Car shut off on the way to work and had to be towed after i couldnt diagnose it. I had no money or help and I don't know much about cars. But I do know that it needs oil, my sensor was bad and i never checked oil manually. I assumed the bearings were toast.
I ran seafoam in the crankcase and gas tank about 3 weeks ago. It was still smoking today after I started it and idled. I've started it about 3 times since the seafoam and tried to drive twice. All times including today it will shut off after a driving in my apartment complex. Usually dies when i slow down to 0rpm. But the car feels weak and wants to die when driving. The idle was also terrible and lumpy all 3 times since the initial breakdown.
Today i found out the Spark plugs were trashed and one of the 4 had oil/gas on it. I just changed them out today with ngk iridium's and the car idled like when i bought it. A high idle but stable. Much better than the idle before I changed the plugs. It usually jumps idle when I'm late to change the oil, but still a higher than normal idle
Things I do know are a different problem. My vtec solenoid is oiled up and most likely had a gasket clogged.
My Airbox hose to the valve cover is broken off. So I guessing my whole intake is gunky
The fuel pump priming can be heard when I turn the key. Im just stunned after changing the plugs and how it purrs at idle and then when i take off it cuts out.
Any ideas what's the culprit
