1 - 4 of 4 Posts
On jhpusa.com they carry the spoon and mugen thermostats and fan switches. my thermostat is broken anyway so might as well get a set, my question is the fan switch they represent will they work for the k series swap. Some say they had to use the fan swtich from the b\d-series engines. Don't the rsx have there own fan switch we can use or is the system different. here is the link http://www.jhpusa.com/catalog/index.php?cPath=21_33_91&osCsid=fce7764fb030ce961724d0902edf5057
you can use the fan switch off and b/d series motor.the switch is all the same..the reason people use the b/d series fan swith is b/c on the dc5/ep3 the fan switch is on the radiator...if you dont buy the radiator from the swap ( which no one hardly does ) the fan switch is still on the radiator...the motor does not have the fan switch/temp sending unit on it... as for a low temp fan switch/thermostat its not pratical to use if tuning with a k-pro or stand alone ecu....also there also can be a idle problem as for the engine never reaches normal operating temp....
you could use something like this:
(sorry for the shite pic, way too much flash!)
it's an electronic fan controler, basically, it drives the fan relay and it's adjustable for temp, it fit's in line with 32mm water pipe. I have them made up for the transplants I do.
1 - 4 of 4 Posts
