This question came to me while doing a 06 rsx-s cluster swap in my del sol
The k20z1 (05-06) has the digital pick up for the vss (like the s2000)while the 02-04 has the the normal style one (like most other hondas)
So i thought since i have the z1 pick up i might as well use an 06 cluster i had laying around instead of buying a $200 speadhealer thingy.
Well my cluster still doesn't work. Im using the z1 engine, z1 harness, an 05-06 k-pro and adapter harness and a z1 cluster....
So i began to research and i found out that it is possible to change the cluster on a 02-04 rsx-s to a 05-06 cluster and still have the speed-o-meter working. which means that the signal coming out of the ecu must be the same whether it is k20a2 tranny or a k20z1 tranny (with its respectable ecu)
so if you have a z1 swap with a 05-06 k-pro, can you get your speedo to work?
i dont know if this subject has been touched already...
