on 98 octaneAffiliatedx3 said:500 wheel hp on pump is gonna be a hard one to accomplish isnt it? what kinda pump gas you got access to? 500 break hp might be easier but again what kind of pump gas we talkin about? 100?
looks like there NOT going to talk !!!c_buz said:I would like to hear the gurus in here chime in because I am planning on doing the same
What thats Crazy StOOpidst00pid said:we built a fairly simple turbo setup on a stock engine and made 424whp on the stock cams. We switched to IPS turbo cams and made 460whp on less boost (15psi). On stock cams and race gas the car made 515whp. All this was done on a GT35R. I think if we were to switch to a GT4067R we could probably make upwards of 500whp on pump gas at 15psi. This is all on the stock engine.
for built engine specs, I would use wiseco pistons and Pauter rods, IPS valvetrain and cams. Keep the compression ratio around 10.5:1 and with a GT4067R you should be able to make over 500 on 17-18psi on pump gas.
I wouldnt expect much to hit 500whp on PUMP gas. I managed 410whp on my stock bore b16 on 14psi. K series has alot more potential all motor instead of turbo; at least my friends have convinced me other wise.Hype-r said:Hi guys
i want to build a 500Wbhp K20a A.K.A stage 3
what kind of engine spec is needed ???
does anyone have a 500bhp car on pump gas ??
any video's etc
