21 - 40 of 76 Posts
Honda Civic eg
Discussion Starter #21
if i go ecu plus kpro, a harness which most are tucked, conversion harness and immobilizer is a few grand
Just to clarify - you need a conversation harness period. With the oem or after market harness. I think you missed that.
second - yeah u can use kpro or ktuner it’s up to you. With the money you spend on ktuner and immobilizer , why not go kpro
Honda Civic eg
Discussion Starter #22
For anyone using a k20r cl7. This is why you can’t use the cl7 half shaft
101589
valid point! which ecu can you use does it have to be 02-04 RSX type s?
Honda Civic eg
Discussion Starter #24 (Edited)
you can use a few , from stock (w/
De-Immobilizer) , jdm some of them don’t have an immobilizer, kpro, ktuner. If you use k pro or k tuner you need to research which one is compatible.
Immobilizer) , jdm without immobilizer, kpro, ktuner. If you use k pro or k tuner you need to research which one is compatible.
thanks for helping me out with questions bro! 1000000% appreciete you. the cl7 was the motor i wanted to go with! so is the bottom the CL7 half shaft?
Honda Civic eg
Discussion Starter #28
so i'm not done with my swap yet, but on the first post / first page, theres a list of all my parts
Honda Civic eg
Discussion Starter #29 (Edited)
Swapped the rsx axles inner hubs today. It was really really easy
101621
Also put the rear Hasport bracket on
101622
Honda Civic eg
Discussion Starter #30 (Edited)
Small new things today. Been taking so long because these things, even though small, had to be shipped. Every time i realize i needed something i have to wait a week. Haha
OEM Honda oil filter, knock sensor, and crank position sensor changed today
101633
101634
101635
Honda Civic eg
Discussion Starter #32 (Edited)
Hellooooo. Been a minute. I put my RSX type s harness on today.
1. this black (bottom) oil sensor plug had to be cut back to reach the plug on the k20r
101767
2. this air sensor has to be removed (2 12mm) from the back of the engine and brought to the front. Or you can cut the harness And move the plug to the back.
101768
all other plugs from your 02-04 harness should plug right in (Change the cpk sensor).
3. lastly the alternator and knock sensor plug (part of the charge harness) - the JDM charge harness has a female plug and RSX Type S engine harness has a female plug. On the JDM CHARGE harness, cut off the female plug. Not go to the JDM ENGINE harness and cut off the male plug about 3 inches away from the plug , and save the wires/pins. Don’t bother unpinning these plugs, the pins are different. Now solder this male plug that you now have, onto the JDM charge harness, where you cut off the female plug earlier. Warning - you’re not cutting anything off the RSX Type s harness. Just cutting the jdm engine harness and jdm charge harness.
101769
Honda Civic eg
Discussion Starter #33
It's been a while since I've posted. I had the motor finished, changed the parts I wanted, and did the wiring, but the body was being painted for over a month.
Happy to announce that it was finally sprayed, so I'll get the baby back within a week.
Wow, very very nice to have an EG hatch built thread here again. It looks awesome SpaceSI 🆙. I see a lot of new OEM parts, that's great. Seems you are located in CA? What header you gonna use to empower the K-engine? What ECU altering system you gonna use to tune it?
Honda Civic eg
Discussion Starter #38
Yeah, I'm in California
I'm running a skunk2 header and a hondata kpro ECU. It's going to be a street car mostly, so when I tune it, it will be modest.
The car is still pretty much the same right now. It's still just a shell. I have to do the brake lines, then progress will really be up.
Nice...hot season now, isn't it? Are you going to BAR it?
Not the badest 4-2-1 header. So bolts on and tuning is your approach to make it ready for street? Did you tune engines before?
I am looking forward to see more progress of it :).
21 - 40 of 76 Posts
