1 - 20 of 76 Posts
Honda Civic eg
Starting this build thread so anyone can follow along. Join me during this covid19 quarantine build. Feel free to offer any advice or cool mods!
parts / build list at the bottom of this post (post 1)
Got this car on March 20th like this. Previous owner had plans but didn’t take it too far. Brakes were cut and firewall was stripped and studs removed. I plan on putting a k series in it and painting it.
101511
101512
101513
my parts list if anybody needs this info:
post mount - k tuned billet k20 post mount (not k24)
AC - stock cl7 compressor w/ hybrid racing kit and 1996 civic condenser
o2 sensor - Denso 234-9005
half shaft intermediate shaft - rsx type s manual or k20z3 2006 civic si
cpk crankshaft position sensor - 37500-PNB-003
rear main seal -91214 rnb a01
knock sensor- 30530 prb a01
axles- RSX 32mm base with swapped inners , swap the inners hub left to right
mounts -Hasport egk4
harness - Used a Rsx 02-04 Type S harness. I didn’t try to use the stock cl7 harness and ecu. The pin out is completely different. Meaning you're not going to get support from vendors.
Sub harness - hybrid racing conversion harness
ecu - k pro
serpentine belt for stock pulley cl7 , no power steering (oem pulley ) - 7PK1700
shifter and cables - stock jdm cl7 cables and shifter . k20 rsx shifter cables will not work. K20 rsx shifter or billet shifter will not work. If you want billet you need the tsx billet shifter
vss - Dakota digital SGI 100BT
charge harness - used the JDM charge harness
throttle cable- hybrid racing throttle cable with “k series “ throttle cable mount
Honda Civic eg
Discussion Starter #2
In the last two weeks i started prepping the car for paint- removed the interior, windshield, quarter glass, trim, molding, side mirrors, side skirts, sunroof, and passenger side engine mount bracket for the K baby
Paint color to be - oem black
101514
101515
101516
101517
101518
101519
Honda Civic eg
Discussion Starter #4 (Edited)
Thanks Clumbz!
Update - installed Hasport egk2 (edit had to exchange to egk4 because the car came out of an tsx) today before painting, for that nice painted mount oem look.
101522
101523
Also cut the hood for clearance
101524
I need to get on my A game with my DA .. I have a k24 ITB setup going in.. work itself is essential so I barely have any time to spare
nights and weekends
I wish unfortunately my car is in another location .. but! I got my swap here at home in a stand lol .. I need a compressor to do my next part of the build .. cams, valvespring and retainers ..
Migz
Honda Civic eg
Discussion Starter #8
Worked on some paint today.
Primer then base. Will clear coat next week.
101532
101533
101534
Honda Civic eg
Discussion Starter #10
working full time and this car has kept be really busy.
Small updates , changed clutch, rear main seal,and throwout bearing
also finished base coating some parts
101561
101563
101564
101565
man im suscribed to this, building my eg hatch!!! Just bought me a full k20z1 swap!! I hope its not to much but will be having some questions if yall don't mind!!
Honda Civic eg
Discussion Starter #14
Finished clear coating today
Way it worked was fix all your parts and sand from 320/400/500/600. Automotive primer, wet sand 600, primer again, wet sand 600, base coast - apply 2 full wet coats. Straight to clear coat if your base is nice. 2 full clear coats.
101568
101569
101570
Nice what car / year is the k20z1 from??
its a 05 full RSX type S swap (engine, trans, half shaft, alternator, starter, etc) 55K miles per carfax, also came with ECU (can't tell if it is for the 05 or not), and wiring harness for the engine. been trying to research the way to go with the wiring since I see that's the only real difference from other k20's.
Honda Civic eg
Discussion Starter #18
sounds like you’ll only need the 02-04 type s ecu and engine harness, and the conversion harness
1 - 20 of 76 Posts
