1 - 20 of 30 Posts
Find SP performance rotors for your car here
SP Performance All Cars Category
Click here to see these products in our catalog and check out the most current pricing.
SP Performance Slotted Brake Rotors With Standard Gray ZRC Finish:
All rotors are provided with our gray ZRC coating. It provides long-lasting protection against corrosion in the most hostile salt-water environments. After being applied, ZRC provides the highest level of galvanic protection. The film of ZRC is conductive. After the coating heats up during use, it bonds permanently to the metal surface. It will not allow the metal to corrode, even when the surface is scratched
Features:
  • Increased pad bite.
  • Reduced Stopping distance.
  • Vents bake pad gases.
  • Improved wet weather braking.
  • Reduced fade for cosistent repetitive stopping.
  • Increased Safety and Reliability.
CorSport USA.
Discussion Starter #6
02-03 Honda Civic Si (4 Lug) SP Performance Front Cross Drilled Brake Rotors ZRC Finish (2)
SP Performance Cross Drilled Brake Rotors have a design that offers the best results possible in cooling and venting brake dust and moisture. Unlike our competition there is no sharp edge on our chamfer. This is accomplished by the use of an outer radius curve rather than a countersink. With the radius curve, or "Sinusoid Curve", it virtually eliminates an edge on the surface of the hole. This smooth surface also makes the rotor more pad friendly by reducing the wear of the pad caused by the friction scraping against a sharp edge.
SP Performance Cross*Drilled Left & Right*Brake Rotors With Standard Gray ZRC Finish:
All rotors are provided with our gray ZRC coating. It provides long-lasting protection against corrosion in the most hostile salt-water environments. After being applied, ZRC provides the highest level of galvanic protection. The film of ZRC is conductive. After the coating heats up during use, it bonds permanently to the metal surface. It will not allow the metal to corrode, even when the surface is scratched.
Features:
Optimized air circulation for increased cooling.*
Increased pad bite.
Reduced fade.
Looks Cool ...Runs Cool.
CorSport USA.
Discussion Starter #7
04-05 Honda Civic Si (5 Lug) SP Performance Rear Diamond Slot Brake Rotors ZRC Finish (2)
The SP Performance Diamond Slotted Brake Rotors are a unique design in slotted technology. This slotted design was created to maximize the out-gassing while maintaining the structural integrity of the rotor. The series of slots and diamond slots “wipes” the surface of the pad, reducing gases which build up and cause brakes to fade at higher temperatures. The slots and diamonds are machined to the minimum rotor thickness to insure rotor strength and integrity. The appearance of this design is highly desirable to the performance enthusiast wanting a new look to their vehicle.*
SP Performance Diamond Slot*Left & Right*Brake Rotors With Standard Gray ZRC Finish:
Features:
Maximum air circulation for increased cooling.
Increased brake pad bite.
Faster release of brake pad gases.
Reduced fade.
Runs cool…..Looks cool*
CorSport USA.
Discussion Starter #11
04-05 Honda Civic Si (5 Lug) SP Performance Rear Drilled And Slotted Brake Rotors ZRC Finish (2)
SP Performance Cross-Drilled and Slotted Brake Rotors are a unique design offering the best combination of cooling and out-gassing. In fact, our design is so unique we would like to go over some of the details. The first thing we will point out on the drilled rotor is the chamfer. Unlike our competition there is no edge on our chamfer. This is accomplished by the use of an outer radius curve rather than a countersink. With the radius curve, or Sinusoid Curve", it virtually eliminates an edge on the surface of the hole. With no edge, there is less stress build up, thus reducing the chance of surface checking. This smooth surface also makes the rotor more pad friendly by reducing the wear of the pad caused by the friction scraping against a sharp edge
SP Performance*Drilled & Slotted Left & Right*Brake Rotors With Standard Gray ZRC Finish:
Advanced Drilling methods put SP Performance Cross Drilled and Slotted Brake Rotors above the rest in quality, performance, reliability and appearance. The rotors are drilled with an exclusive Sinusoid Curve chamfering which promotes cooling. It also vents moisture and dust while minimizing heat checking and increases both rotor and pad life.
Features:
Maximum air circulation for increased cooling.*
Reduced fade.
CorSport USA.
Discussion Starter #20
Features:
Reduced fade.
CorSport USA.
1 - 20 of 30 Posts
