Status
Not open for further replies.
1 - 20 of 23 Posts
good question...... you should go to your local CHP office and ask questions first. as "I wanted to do this swap" but i think it's the same as putting a B series in an EF model
Don't you mean referee center? Most are situated at your local community college. Here is the scheduling center number (800) 622-7733.
I thought the issue with making the K20 swap BAR legal in California was the fact that in the ef/eg/ek/etc. you have to run a fuel pressure regulator, and aftermarket fuel pressure regulators are not CARB legal. Please correct me if I am wrong. Visiting the ref a few times, I know that these guys know there sh*t.
You dont have to do this if you are able to change the fuel system to the RSX one. :D
The only other way is to get a FPS that doesnt look like one... you'd have to trick the tech or something... lol
Fuel Pressure Regulator isnt the problem.
All you have to do is put a fuel pressure regulator from a Civic on the RSX motor, it will regulate it to 38 PSI with the hose on. Its stock honda.
Jeff
1 - 20 of 23 Posts
Status
