21 - 40 of 51 Posts
Discussion Starter #21
2002-2006 Acura RSX Skunk2 Pro-C Coilovers
Skunk2’s industry-leading Pro-C Coilovers for the '02-'06 RSX feature 12-way adjustable valving, adjustable ride height, and a state-of-the-art mono-tube design. Thanks to threaded shock bodies, Pro-C Coilovers offer height adjustments independent of spring preload, which results in significant ride-height changes without sacrificing shock travel or ride comfort. Quick and precise ride-height adjustments can be made for dialing in corner balancing as well as for improved handling, responsiveness, and overall balance. Skunk2’s track- and street-tested Pro-C shock valving offers the perfect balance between daily driving and track performance and its all-new, shortened shock bodies and reduced shaft strokes help maintain adequate suspension travel on lowered vehicles for improved*performance without sacrificing comfort.
Pro-C Coilovers feature vehicle-specific, carefully selected springs designed to dramatically improve handling, and a race-inspired, mono-tube design for superior performance. Skunk2’s micro-polished, mono-tube design and one-piece, forged shock bodies, combined with its precision-machined, oversized shafts and stainless steel pistons, ensure that each Pro-C Coilover is both responsive and durable. Each Pro-C Coilover also features the highest quality shock oil for consistent performance and triple upper and lower seals to ensure years of leak-free operation. The results are unmatched cornering grip, reduced body roll, and a feel of vehicle control and stability like no other.
Pro-C Coilovers feature hard-anodized, CNC-machined, forged 6061-T6 aluminum spring perches and CNC-wound racing springs manufactured from high-quality, SAE9254V spring steel. Each spring is designed to optimize the balance between comfort and performance and is custom-matched to their respective shocks. Pro-C Coilovers offer ride-height adjustments as low as three inches for an aggressive and sporty appearance.
Just like the entire Pro Series lineup, Pro-C Coilovers set the benchmark for suspension performance. Similar to how Skunk2’s Pro Series Camshafts and Valvetrain revolutionized Honda engine performance, its fully adjustable, Pro-C Coilovers do just that for enthusiasts who are looking for high-performance suspension components at an affordable price. Based on more than 15 years of racing and suspension tuning experience, Pro-C Coilovers feature the same technology Skunk2 uses on its own championship-winning road racing and drag racing cars.
Like all Skunk2 products, Pro-C Coilovers feature a one-year warranty and are designed to provide years of enjoyment for the life of your vehicle. Never wait for a coilover rebuild again; Skunk2 stocks large quantities of replacement dampers that, in most cases, cost less than a typical coilover rebuild. Purchase your replacement dampers directly from Skunk2 to minimize downtime.*
CorSport USA.
Discussion Starter #24
02-06 Acura RSX Skunk2 K-Series Black Series Pro Series Intake Manifold
Skunk2's engineers looked to the popular '06-'10 Civic Si’s RBC intake manifold for inspiration when developing our Pro Series Intake Manifold for K-series engines (excluding '06-'10 Civic Si) and went back to the drawing board.*
Each of Skunk2’s Pro Series Intake Manifolds for Honda’s K-series engines feature larger plenums and shorter, oversized runners when compared to the RBC, and are cast with thicker wall material, leaving room for further porting for high-horsepower applications. Instead of producing a manifold with a significantly oversized plenum and excessively short runners that would sacrifice mid-range power, Pro Series manifolds were designed for the “street enthusiast” who wants more power but doesn’t want to sacrifice mid-range performance to get it. The results are improved airflow, an enhanced venturi effect, and both mid-range and top-end power gains.
Skunk2’s all-new, cast-aluminum Pro Series Intake Manifolds for Honda’s K-series engines are a direct-fit replacement for all K-series engines (excluding '06-'10 Civic Si) thanks to their unique, patent-pending water neck designs and throttle body flanges, which are compatible with OEM throttle bodies as well as those as large as 76mm. The special water neck designs eliminate the cutting that would otherwise be involved with some RBC applications and the supplied thermal-insulated intake manifold gasket makes for a truly bolt-on installation (no drilling or modifying required). Pro Series manifolds also incorporate an angled-runner design, which allows for ample hood clearance on ’88-’00 Civics and ’90-’01 Integras with K-series engine swaps, as well as additional core support clearance on ’02-’05 Civic Sis.
Pro Series Intake Manifolds offer horsepower and torque gains greater than the popular RBC manifold but without compromising mid-range power output. The design incorporates runners that are similar in length to the RBC’s but with larger bores, a special tapered design, as well as a larger, tapered plenum that together preserve mid-range power but increase and accelerate airflow to allow for significant top-end power gains. Pro Series Intake Manifold runner exits are also machined and hand-finished to best match the cylinder head’s ports. Skunk2’s Pro Series Intake Manifold’s shape and design also increases wave scavenging effects at the engine’s ideal operating range, which allow for a broad increase in usable power.*
Skunk2 is a familiar name in the intake manifold business, with more than 10 years of experience designing, testing, and building them. Similar to OEM manifolds, Skunk2’s Pro Series Intake Manifolds are shell-molded from 356-aluminum, CNC-machined for superior strength, a precise fit, and a high-quality finish, and vacuum-tested for quality. Each manifold is molded with smooth transitions from the throttle body opening to the plenum to the runners with clean parting lines for an optimal finish, both inside and out and features a genuine Skunk2 nameplate. *
Note:
Ideal for turbocharged and naturally aspirated applications.
70mm throttle body opening can be port-matched up to 76mm.
Not compatible with '06-'10 Civic Si K-series engine.
Part Number Fits:*
2002 - 2006 Acura RSX (Base, Type-S)
2002 - 2005 Honda Civic Hatchback (Si)
CorSport USA.
Discussion Starter #25 (Edited)
02-05 Civic Si Skunk2 Stage II Camshafts
Skunk2 Racing camshaft profiles are designed using the latest computerized valvetrain and modeling techniques to maximize horsepower and torque. Our camshafts are designed utilizing years of racing experience. These camshaft blanks are cast from the same foundries used by auto manufacturers such as Toyota, Nissan, Honda, and Mitsubishi, and utilize the latest in Japanese chill-casting technology. Skunk2 Racing camshafts are ground to exact specification using CNC cam grinding machines and are subjected to hours of performance and durability testing. Skunk2 Racing camshafts must pass stringent quality control standards that exceed OE requirements.
Stage II: Stage II profiles are more aggressive than Stage I profiles, and are designed for modified engines operating at higher rev ranges. Upgrading to Skunk2 Racing valvetrain components is required for proper operation. Stock idle and emission characteristics may be slightly compromised, but fair-to-good driveability allows them to still be used on dual-purpose vehicles. Proper tuning, an upgraded intake system, and an exhaust system are required in order to maximize the potential of these camshafts. Do not use oversized valves.
CorSport USA.
Discussion Starter #29
02-05 Honda Civic Si Skunk2 74mm Pro Series Throttle Body
Skunk2 is proud to introduce its 74mm Pro Series Throttle Body for the RSX Type-S and Pro Series Intake Manifold (part number 307-05-0310) in its signature, hard anodized finish—the biggest K-series throttle body you can buy. Skunk2’s Pro Series Throttle Bodies are designed to be used with OEM Acura RSX (PRB) or Skunk2 Pro Series Intake Manifolds for bolt-on horsepower and torque gains by optimizing engine airflow (other applications, including ’06+ Civic Si RBC manifolds, require adapter plate).
Skunk2 throttle bodies undergo an extensive design and testing process to produce a throttle body that doesn't just provide more flow but retains smooth drivability and OEM throttle characteristics. Each Pro Series Throttle Body is designed using the latest CAE (Computer Aided Engineering) tools, which results in a unit that exceeds industry standards. Pro Series Throttle Bodies are also CNC machined from forged, billet 6061-T6 aluminum and hard anodized for durability in Skunk2’s signature finish. Pro Series Throttle Bodies are also compatible with OEM throttle cables, which simplifies installation. Each Skunk2 Pro Series Throttle body also features sealed bearings for smooth operation and a genuine, integrated Skunk2 badge. All necessary hardware and a new throttle body gasket are included for trouble-free installation.
A larger throttle body is key to producing additional power throughout the powerband on modified engines with increased airflow demands. Skunk2’s Pro Series Throttle Bodies for K-series engines feature a 74mm bore, which results in significant horsepower gains throughout the powerband on naturally aspirated applications and even more on forced induction ones.
Note:
Complement your Pro Series Throttle Body with a Pro Series Intake Manifold for increased airflow.
Part Number Fits:
2002 - 2006 Acura RSX (Type-S)
Acura K20A2, Z1
CorSport USA.
Discussion Starter #30
03-08 Acura TSX Skunk2 MegaPower Catback Exhaust
03-05 Acura TSX Skunk2 MegaPower Catback Exhaust
Skunk2 Mega Power cat-back systems are constructed from T-304 stainless steel and feature Japanese Super-N1design and styling. Each exhaust is mandrel-bent using properly sized tubing for maximum flow and is finished off with a low restriction racing muffler. Most mufflers feature a single 110mm polished tip with an acid-etched Skunk2 Racing badge. Systems are available in standard and full-polished finishes. Each system comes complete with a removable silencer and all necessary hardware. Mega Power universal mufflers are also available separately.
Note: DUAL MUFFLER
CorSport USA.
Discussion Starter #32
Skunk2 Large Fender Washer Kit - 6 Washers & Bolts (Black)
Skunk2 Fender Washers were designed to replace the factory hardware with stainless steel bolts flush-mounted inside of our unique, hard-anodized aluminum washers. Each kit includes six low-profile, 20mm-diameter washers and six flush-mounted, stainless steel bolts. Skunk2 Fender Washers are direct replacements for many Honda components that utilize 6Mx1.0 hardware, like fenders, headlights, radiator stays, hood hinges, and more. Only Skunk2 Fender Washers offer the most low-profile washers and bolts around, measuring more than 75% thinner than the factory washer and bolt combination.
Skunk2 Fender Washers are manufactured from 6061-T6 aluminum, include high-quality, grade 10.9 metric bolts, are available in black, blue, gold, purple, red, and clear hard-anodized finishes, and feature Skunk2’s classic, laser-etched logo. Skunk2 employs the same design and manufacturing methods for all of its Fine Tuning accessories as it does for its top-of-the-line racing components. Skunk2 Fender Washer Kits help put that unique finishing touch onto the vehicle you work so hard to make perform well, and we make every effort to ensure that their style is consistent with our rich racing heritage.
Note:
Kits include 6Mx15Mx1.0 flush-mounted, stainless steel bolts.
For smaller, 16.8mm-diameter washers, see Small Fender Washer Kits.
Kits include six washers and six bolts.
CorSport USA.
Discussion Starter #33
02-05 Honda Civic Si K20A3/K24A1 Skunk2 Megapower Header
The Skunk2 MegaPower Header is designed and engineered to maximize exhaust flow and increase both horsepower and torque throughout the entire RPM powerband. Our unique design is the result of over a decade of racing experience coupled with computerized modeling and extensive dyno testing. Each Skunk2 MegaPower Header features equal length, sequentially-paired, stepped primaries and a 4-2-1 Tri-Y design with a 2.5 inch collector. These features coupled with our unique design specs provide an extremely broad powerband that can be used on a wide range of engine sizes and configurations. Each header is constructed from T-304 stainless steel with fully polished, mandrel-bent tubing and a CNC-machined flange for added strength and durability.
Fits:
Acura K20A2, A3, Z1
Acura K24A2
Honda K20A3, Z3
Honda K24A1, A4, A8, Z1
CorSport USA.
Discussion Starter #37
02-05 Honda Civic Si Skunk2 Black Series Rear Lower Control Arms
Skunk2’s Black Series Rear Lower Control Arms for the ’01-’05 Civic are based off of the same technology the company’s been using on its own race cars for more than a decade and are a must-have for enthusiasts looking to fine-tune their suspension for maximum handling performance.*
Skunk2’s Rear Lower Control Arms are direct replacements, maintain OEM suspension geometry, and are ideal for street and race applications. Each arm is forged from aircraft-quality 2024 billet aluminum, precision CNC-machined, and is more than 25 percent lighter than the OEM arms. Skunk2 Rear Lower Control Arms also feature adjustable anti-sway bar mounting holes for advanced suspension tuning and optimum balance. The low-deflection, polyurethane bushings act as bearings for quicker response and a more positive feel. Skunk2 also eliminated tearing and un-seating problems typically associated with other fixed rubber bushings by allowing the arm to rotate freely about the bushings. *
Properly designed suspension components must be strong and functional first and aesthetically pleasing second. Skunk2’s Rear Lower Control Arms are both. Each arm’s I-beam shape and tapered design is a direct result of efforts to eliminate twisting, bending, and stress risers. Extensive FEA (finite element analysis) testing determined that conventional “straight and flat” designs are plagued by internal stress risers. A poorly designed arm will concentrate stress in particular zones, causing the arm to fracture and ultimately fail.*
For maximum suspension performance, Skunk2 Rear Lower Control Arms are best complemented with Skunk2 Rear Camber Kits, Lower Arm Bars, and Strut Tower Bars.
Note:
Sold in pairs.
Industry-leading, low-deflection polyurethane bushings are included with all Skunk2 LCAs.
Part Number Fits:
2001 - 2005 Honda Civic Coupe (DX, EX, HX, LX)
2001 - 2005 Honda Civic Sedan (DX, EX)
2001 - 2004 Honda Civic Sedan (GX)
2001 - 2003 Honda Civic Sedan (LX)
CorSport USA.
21 - 40 of 51 Posts
