1 - 16 of 16 Posts
What’s up k20 family! My setup consists of a sidewinder and I was wondering if any of you guys are running this side cover oil drain? Seems like a long haul for the drain vs at the pan. Let’s hear your opinions. Thanks
Automotive tire Gas Space Machine Automotive wheel system
Motor vehicle Vehicle Hood Automotive air manifold Automotive exterior
White Automotive lighting Light Vision care Hood
I’d be worried about the angle of the drain. Definitely better in my opinion to have it go to the pan. More gravity 😅. But never seen that setup to be honest. Looks more form over function.
My question is why or what reason is this part made with a -10AN lines? I understand oil lines that are under pressure being -10AN lets say for remote oil coolers & oil filter relocation applications. I do not think the drain will perform any better being -10.
97 civic HX K24a
I have always used a -10 drain line for b series because the oem coolant fitting on the head is what we welded to the pan and a -10 pushlock hose fits perfectly over it. I think a lot of turbos have a -10 drain.
Discussion Starter · #9 ·
I honestly don’t know why it’s the most commonly used size I just assumed for easy flow 🤷🏾‍♂️ I’ve seen 2 different versions of this piece now and was wondering how many people actually have it out there. Thanks
The funny thing is the tensioner is right there so your basically pumping hot oil from ur turbo onto your tensioner which I wouldn’t want to be doing
Discussion Starter · #11 ·
That is literally the same thing I thought! Why would I send hot oil straight to tensioner.
Yeah this is confusing. Better use as a crankcase breather position than a turbo drain. You want the gravity drain to be as vertical as possible, but -10 is all I have ever used.
97 civic HX K24a
I think that tensioner piece is more for the guys who are too lazy to do the oil pan the right way. It’s a pain in the ass with the motor in the car. But honestly every turbo kit I’ve ever seen on a Honda motor used an oil pan -10 drain from the turbo downwards.
I just want to know the reason why -10 is the choice size. If it works great.
You have a great point using that as a crankcase breather vs. a turbo drain.
1 - 16 of 16 Posts
