1 - 3 of 3 Posts
Just wondering if anyone has done this because my pedal is very sloppy and loose feeling, and the cable is set to be as tight as it can,
can i just get the connecter and crimp it on or something to shorten it? has anyone else even needed to do this?
You can space out the bracket taht holds the cable housing at the t-body or use a couple of zip ties to take up some of the slack at the accelerator pedal by putting the zip ties around the cable between the rubber bump stop and cable end.
brian g
1 - 3 of 3 Posts
