1 - 19 of 19 Posts
Ive been looking for this everywhere, i need the second gear for my k series tranny, 02-06 rsx 6spd, 06+ si.
if anyone know where to get this part, any info will help me out thanx
i searched for 23431-PNS-000, this part number was listed here in k20a.org as an unlisted part number, it came out to be a base model rsx second gear.
· HONDA HEAVEN RIP
Re: Sencond gear
there is no way possible to just wear the triangle teeth on the gear alone. look at the selector, where those triangles slide in, ya those are mashed down. now when you put a new gear with old synchro your going to murder that new gear from mashing the unaligned old selector. also when you look at the triangles on the synchro they are fine, but as the triangle gets fatter towards the round part you can see it not stay so fat. change the hole second gear set.
Re: Sencond gear
Thanx for helpin bro, but I only need the gear, everything else is fine, I just wor out the little diamond teeth.
Agreed. You are absolutely wasting time to JUST change the gear. The gear slide pin, syncro all work together and fail together. Replace the whole gear set, you are going to spend almost $400 after replacing the gear set, axle seal, and the 3 needle bearings in it.
Re: Sencond gear
Thats why people send their trannies to me, $450 for a rebuild including parts and shipping has been a deal many have taken advantage of :)
Discussion Starter · #7 ·
Re: Sencond gear
Thanks again but I'm not a noob on this so im 100% sure I just need the second gear, reason being that I'm the one who took the tranny apart, all the gears apart, and also because I have a new synchros allready from another tranny rebuild I did in the past.
Re: Sencond gear
I just ordered the 23431-PNS-000 part number and it's the 6spd 2nd gear, I'll post pictures later today in the unlisted transmission parts thread.
· HONDA HEAVEN RIP
Re: Sencond gear
do you have a brand new slider?
Re: Sencond gear
My thoughts exactly but he seem's to have his mind set that just the gear is bad. I guess where a few of us are coming from is that the parts do fail together and work together, and should be replaced all together. :up:
Re: Sencond gear
in my case, the teeth on the gear wore much more than the teeth on the slider.
Brass teeth on synchro
Teeth on 2nd gear
Teeth on slider, 2nd gear side is up.
So really, the 2nd gear was the only piece I needed to replace badly. Ideally I'd replace them as a set, but my 2nd gear shifts fine at 9000rpm. I just figure that if I can replace the gear while I have it cracked open, it'll last a bit longer before the whole thing fails. Worth it for $60 IMO.
Discussion Starter · #14 ·
Re: Sencond gear
Teeth on 2nd gear
thank you, and thats that mine 2nd gear is'nt that bad....so yeah, ima order the gear tomorrow, well see what happens.:up:
· HONDA HEAVEN RIP
wow my second was way worse then that, the slider also. i have them at home im gonna take some pics, how in the hell did the gear get so shot and not the slider? crazy
Discussion Starter · #16 ·
it depends if you **** up the gear in one shot itll be really bad, if it happen in time then it wont be that bad.
cool cool. I still wonder why it came up as a base RSX 2nd gear.
Yeah, I was surprised to see that only the gear was badly damaged. Normally, you'd think they'd fail together. I guess the slider is somewhat harder than the teeth on the gear?
Well, my 2nd gear looked like that from when I first got the trans with about 30k miles on it. I bought it on ebay, cracked it open to put the final drive in, and saw that. It hasn't really gotten any worse in the 70k miles or so that I've put on the trans since I first put it in the car. Either way, for $6x bucks, I figure it's worth putting in a new 2nd to ensure things stay smooth for some time to come.
1 - 19 of 19 Posts
