Okay, snapped some pics in my freezing cold garage...
K-Tuned traction bar
EG brake booster downgraded from ITR. Didn't want to make new brake lines although I have the tubing, flare nuts and flare tool. Also, shown is how I looped my power steering rack. Just need reservoir now.
HR/Innovative side mount.
K20Z3 with HR side mount and DC header.
Unopened K24A1 ready to be bored out. Also, K20A2 with cracked cylinder from my RSX-S.
Tranny with HR mount.
Tranny code from K20Z3.
5 lug fronts. CRV knuckle with CRV/RSX bearing, RSX-S hub, TSX slotted rotor (ATE PremiumOne), RSX-S caliper brackets pushed out using 1mm washers because TSX rotor is thicker towards outside (washers not shown).
Bench bleeding EF 15/16" brake master cylinder. Also shown is Omni S2000 clutch master cylinder with no reservoir (doesn't come with one).
Interior: DC5 Integra Type R wheel, EK steering column (with spacer circled in red), DC2 Integra Type Rx pedals (pedal covers for gas/clutch available from Honda if you ask for 06 Civic Si pedal covers) and S2000 AP1 seat.
Stuff on top of trunk... DC2 ITR rear brakes, 06 Si (or was it TSX?) shift knob, HR shifter, HR shifter cables
Supertech 12.5:1 CR pistons and unknown K24 rod for future K24A1 build. I'll get to it when I'm willing to crack open the K20Z3.
Messy garage... From left to right, K24A1, K20A2 block and K20Z3.
New radiator support with HR/Griffin K-swap full radiator.
06 Civic EX 16" fat five wheels for the stock/sleeper look.
OBX twin loop exhaust.
