1 - 15 of 15 Posts
Hey Guys, have another batch of S2k pumps in progress at the shop right now. Get them while they're here!
I had a thought/question: you know how the old type s or type r oil pump was cavitating before its limit and people had to mod them by making a hole bigger or something like that. So wouldn't that same mod give the s2000 pump even more flow or higher caviatating limit?
how much?
Discussion Starter #13
The oil chain tensioners are the same on the K20 an K24 correct?
Part # 13450-RAA-A02
Also will the K20 oil chain guide work with this as well?
I'm pretty sure they're not the same but that's the correct part number you've referenced. yes, all of this is discussed way earlier in this thread....the K20 chain guide is the one you want if you don't want to cut the K24 one.
1 - 15 of 15 Posts
