81 - 90 of 90 Posts
Yep, on the very first page of this thread I posted a pic of the k20 windage tray and the necessary modification to make it fit. You really don't want to run your motor without the windage tray. The k20 tray is better because it is one continuous piece...but you could probably get away with the k24 tray.
on K24a3 you don't need any modifications to fit K20 windage tray - all is bolt on. I asume same is valid for K24a2.
So a small update for some of you using k20z4 engine (fn2) and some pics tomorrow
The oil pump chain from the k20z4 is bolt on with the s2000 oil pump, i believe it is the same as k24
No need to cut the chain guide if you have a k20a2 one, it is bolt on, also use the oem k20z4 chain tensioner
k20a2 tray its bolt on into k20z4
Some small mod is needed to the k20z4 oil pan to fit, workink on it and tomorrow ill have the final result, im almost certain if done carefully you can get it to work without aluminium soldering, altough thats not mau case :blur:
Pics
Killed the biatch
k20z4 Oil pan so far...still working on it
Guide comparison
81 - 90 of 90 Posts
