1 - 14 of 14 Posts
I/h/E tuned is not semi built.
also..don't think you'll stand a chance with all that power.
470/440 at the wheels forget about it, 470/440 you got a chance if you're trapping like 111-112 it i'll be a driver race. Have a friend 08 GT, Kenne Bell S/C 12 psi, exhaust/headers puts out 450/[email protected] runs [email protected] on drag radials. I smoke him tho so chalk one up for the Ks :D
I typed semi-built k20a2 then comma. Intake, headers, exhuast and tune are my mods.
BuddyClub spec3 camshaft
BuddyClub valvesprings
BuddyClub retainers
RBC intake manifold
RDX 410cc fuel injectors
DC swap header
AEM fuel rail
AEM cold air intake
3 angle valve job
PRC Type R pistons
fidanza 7.5lbs flywheel
cc stg 2
How about now? I think it is semi-built.
Gives me hope! Am I going to get killed or at least hang?
wut tires is the guy u kno running? i dont think the azenis will fair if he has better tires.
BuddyClub retainers
RBC intake manifold
DC swap header
AEM fuel rail
AEM cold air intake
3 angle valve job
PRC Type R pistons
cc stg 2
that list is a bit better now.
what numbers are you putting down?
how heavy is the car with driver?
how good of a driver are you?
i dunno..that is quite a bit of power you're messing with there. 470 to the wheels?!
Discussion Starter · #10 ·
http://www.youtube.com/watch?v=VIDnVrDOIwY&feature=channel_page
http://www.youtube.com/watch?v=Oe-EUizeaxI&feature=channel_page
Im thinking that he will keep spinning, which would give me the edge and pull on him.
For numbers, im putting down around 225-230ish, My car has no sound deadening and the hatch is pretty much gutted. As for driving skills, im not too bad, although I am no professional, I can run through the gears pretty quick and careful without missing.
Racing and video might happen this weekend, hopefully.
well its worth a try, in my opinion unless he is running slicks, he is going to spin like nobodies business because those tires arent great. worth a try... if he wins i doubt it would be buy that much. 400 hp is nice but it does weight alot.
^^power is kinda low for a built frank motor isn't it? what is your full set up?
1 - 14 of 14 Posts
