Status
Not open for further replies.
21 - 34 of 34 Posts
bump :up:
so for $4500 your giving this?
S2000 Transmission adapter plate
Clutchmasters custom swap Flywheel (allows the use of OEM s2000 clutch and pressure plate)
Modified S2000 Innovative motor/transmission mounts
Custom Wire harness adapter:
-Allows you to plug a K series engine harness and pro into the OEM s2000 chassis harness
-Throws one code forP0563 otherwise integrates with all OEM systems except coolant temp (which can be connected with a modifry adapter)
Magnus K Series Manifold custom made for this car/application
Ktuned alternator relocation kit (required to run Magnus manifold)
Ktuned, upper coolant housings with 12AN flange for use with K24a2 or K24A1
Modified s2000 header with 2.5" V-band welded in place of stock flange
cause I find it a bit steep as you can almost purchase a turbo kit and half the hassle to put it in.
Nice! I remember reading the article on this! If I had an S2K I would def get this!
21 - 34 of 34 Posts
Status
