1 - 2 of 2 Posts
you wire it the same way you would on a stock EG/dc with their stock engines and use/buy a speedohealer v4 to correct the Vss signal to display the correct mph if your transmission is an 02-04 type-s or a 5 speed one.
for the temp i used a standalone gauge on mine. since they are more curate as far as showing you an specific temp instead of the s2k cluster that turns on a led for a temp range.
DC cluster pin out:
http://www.marklamond.co.uk/products/s2000/install/pinout/dc2_cluster_jdm.pdf
2000 s2k cluster pin out:
http://www.marklamond.co.uk/products/s2000/install/pinout/ap1_cluster.pdf
2004 s2k cluster pin out:
http://www.marklamond.co.uk/products/s2000/install/pinout/ap2_cluster.pdf
1 - 2 of 2 Posts
